IntraDomain Presence and OCSr2 - TLS issue
blwegrzyn
I setup the intrafederation according to :
http://www.cisco.com/en/US/docs/voice_ip_comm/cups/8_6/english/integration_notes/Federation/Intradomain_Federation/CUPConfig_chapter.html
I can only talk to Presence from OCSr2 but not the other way.
Also both presence status in ocsr2 and jabber does not work between the ocsr2 and presence.
If i switch the static route 5060 all works, but with 5061 it does not.
Below is the log where "jabbertest1" presence user invites "wegrzyn" OCSr2 user.
I see error like:
11:31:59.928  |ID(2492) sip_sm.c(3738) Route DooS is On for next hop  [10.100.50.81:5061;TLS]. No routes left to process. Terminate the branch  with 404 Not Found.
but i am not sure what this means?
full log:
11:31:59.926 |PID(2492) sip_protocol.c(5994) Received 588 bytes TCP packet from 10.100.95.15:46137
INVITE sip:wegrzyn@equityoffice.com SIP/2.0
From: <sip:jabbertest1@equityoffice.com>;tag=afe8a888-f5f640a-13d8-45026-4ffefbff-382e5d7-4ffefbff
To: <sip:wegrzyn@equityoffice.com>
Call-ID: ae67af10-f5f640a-13d8-45026-4ffefbff-a1bd6a9-4ffefbff
CSeq: 1 INVITE
Via: SIP/2.0/TCP 10.100.95.15:5080;branch=z9hG4bK-4ffefbff-7c085fb5-5cf09ddd
User-Agent: Cisco-Systems-Partitioned 8.0
Max-Forwards: 70
Contact: <sip:10.100.95.15:5080;transport=TCP>
Content-Type: application/sdp
Content-Length: 87
v=0
o=- 0 0 IN IP4 0.0.0.0
s=session
c=IN IP4 0.0.0.0
t=0 0
m=message 5060 sip 0
11:31:59.926  |Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_numexpand.c(891) User  wegrzyn is IP or contains non-E164 character, no number expansion  applied.
11:31:59.926  |[Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_numexpand.c(891) User  jabbertest1 is IP or contains non-E164 character, no number expansion  applied.
11:31:59.926 |PID(2492) sip_sm.c(1177) Sent 357 bytes TCP packet to 10.100.95.15:46137
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 10.100.95.15:5080;received=10.100.95.15;branch=z9hG4bK-4ffefbff-7c085fb5-5cf09ddd
CSeq: 1 INVITE
Content-Length: 0
11:31:59.926 |PID(2492) sip_sm.c(967) TCB_PROXIED_STATE_TIMER : 60 seconds.
11:31:59.926 |ID(2492) sip_sm.c(4846) Non-CUPC request received from IP: 10.100.95.15
11:31:59.926 |PID(2492) mod_sip.c(2950) us_validate_msft_fed_header(): User Agent Header is invalid
11:31:59.926 |ID(2492) sip_sm.c(5027) SIPGW Partitioned Fed UA Header found in this request
11:31:59.926 |ID(2492) sip_sm.c(5060) This is a partitioned federation request, skip User Location DB lookup
11:31:59.926 |ID(2492) sip_sm.c(5250) This is an outbound Partitioned federation request.
11:31:59.926  |[Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_numexpand.c(891) User  wegrzyn is IP or contains non-E164 character, no number expansion  applied.
11:31:59.926 |Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_routing.c(1426) Routing: dipping for equityoffice.com
11:31:59.926  |Thu Jul 12 11:31:59 2012] PID(2492) imdb_regroute.c(305)  imdb_find_route(): imdb_find_route: search_key is .com.equityoffice,  r_type is 0
11:31:59.926  |[Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_imdb.cpp(174)  IMDBFindRouteInternal(): IMDBFindRouteInternal: query is select * from  route where contactuser_type = 1;
11:31:59.927 |Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(5499) IPC message read event
11:31:59.927  |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(3886) sip_tcp received  auth state as: 0 for connid: 3 sockfd 34 flags 2 from sip_sm
11:31:59.927 |Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(5526) socket write event on: 34
11:31:59.927 |Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(4688) Inside sip_tcp_write_handler
11:31:59.927  |Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(680) sip_tcp is now  sending ok pdu 10.100.95.15 connid 3, sock_fd 34 1 msgs
11:31:59.927 |Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(5526) socket write event on: 8
11:31:59.928  |[Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_imdb.cpp(975)  clearRouteIMDBConnection(): clear IMDB route connection
11:31:59.928 |Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_imdb.cpp(263) findMatchingRoutes(): search_key is .com.equityoffice
11:31:59.928  |[Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_imdb.cpp(269)  findMatchingRoutes(): destinationpattern is .com.equityoffice, strloc is  .com.equityoffice
11:31:59.928  |Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_routing.c(1464) Routing:  Found domain route for equityoffice.com:10.100.50.81:5061;TLS pwf 1:1:5
11:31:59.928 |ID(2492) mod_sip_privacy.c(1197) Honor Privacy at receive. Privacy directive is On.
11:31:59.928 |ID(2492) mod_sip_privacy.c(1257) Upstream 10.100.95.15 is a trusted address.
11:31:59.928 |ID(2492) mod_sip_privacy.c(1265) PrivacyWithPAI is On.
11:31:59.928 |ID(2492) mod_sip_privacy.c(686) Request not authenticated, no PAI header added
11:31:59.928 |ID(2492) mod_sip_privacy.c(1285) PrivacyWithRPID is Off.
11:31:59.928  |[Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_numexpand.c(891) User  wegrzyn is IP or contains non-E164 character, no number expansion  applied.
11:31:59.928  |ID(2492) mod_sip_rtf.c(302) rtf_check_bad_route(): input  CISCO-UA_RTF-10.100.50.81-5061-TLS@corp-cups01, output  52c26fc6-c260b127-521c1ffd-45002f47
11:31:59.928 |Thu Jul 12 11:31:59 2012] PID(2492) mod_sip_routing.c(1297) Not to do Less Specific Route Search.
11:31:59.928 |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(5499) IPC message read event
11:31:59.928  |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(3886) sip_tcp received  auth state as: 0 for connid: 3 sockfd 34 flags 2 from sip_sm
11:31:59.928 |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(5526) socket write event on: 34
11:31:59.928 |Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(4688) Inside sip_tcp_write_handler
11:31:59.928  |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(680) sip_tcp is now  sending ok pdu 10.100.95.15 connid 3, sock_fd 34 1 msgs
11:31:59.928 |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(5526) socket write event on: 8
11:31:59.929 |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(5521) socket read event on: 34
11:31:59.929 |Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(4536) Inside sip_tcp_read_handler
11:31:59.929  |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(638) sip_tcp is now  reporting pdu to state machine 10.100.95.15 connid 3, sock_fd 34 0 msgs
11:31:59.929 |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(5526) socket write event on: 8
11:31:59.929 |[Thu Jul 12 11:31:59 2012] PID(1580) sip_tcp.c(4688) Inside sip_tcp_write_handler
11:31:59.929 |ID(2497) sip_protocol.c(5994) Received 442 bytes TCP packet from 10.100.95.15:46137
ACK sip:wegrzyn@equityoffice.com SIP/2.0
To: <sip:wegrzyn@equityoffice.com>;tag=7512ace9-69319ade
CSeq: 1 ACK
Max-Forwards: 70
Content-Length: 0
11:31:59.929  |Thu Jul 12 11:31:59 2012] PID(2497) mod_sip_numexpand.c(891) User  wegrzyn is IP or contains non-E164 character, no number expansion  applied.
11:31:59.929  |Thu Jul 12 11:31:59 2012] PID(2497) mod_sip_numexpand.c(891) User  jabbertest1 is IP or contains non-E164 character, no number expansion  applied.
11:31:59.929 |PID(2492) sip_sm.c(1177) Sent 413 bytes TCP packet to 10.100.95.15:46137
SIP/2.0 404 Not Found - Route Dynamic Out of Service
CSeq: 1 INVITE
Content-Length: 0
Tommer Catlin
Is TLS configured correctly on the CUPS server?   If it does not have the cert, it will not "talk" TLS to OCS Pool server
andri
Level 5
Level 5
Did you figure out what the problem was ?
Andri
not, yet , seems like issue with osc not responding on time, still investigating
Did you figure this out?  having the same issue.
