08-31-2007 12:51 PM - edited 03-18-2019 07:46 PM
Hello
Have a question, My customer just plugged a phone to the Network and Its stuck in "configuring ip" we have auto-registration enabled, we have enough DNs available for this purpose, we issued a factory reset to the phone and we are still not able to register the phone correctly, it is a 7940 and we are running CCM 4.1(3) sr4d
Solved! Go to Solution.
10-25-2007 11:17 AM
Cris, did you ever get this resolved?? I have come across the same issue for a customer.
08-31-2007 01:26 PM
Is DHCP configured with option 150 pointing to the TFTP server?
Do you have a voice (aux) vlan configured on the switch port the phone is connected to? If so, try connecting it to a switch port with the only one vlan configured that has access to the dhcp scope with the option 150 configured.
Some of the old 7940/7960 firmware had an issue with connecting correctly to switches that had an aux VLAN configured.
09-02-2007 11:38 PM
Dear, Simply add manul entry in DHCP with MAC Address of the phone and IP. you will then have to reset the phone. Hope that will work! otherwise please let me know do you have any vlans configured. If yes then please use 'Switchport voice vlan #' on that IP phone port. Please update the status after all
09-04-2007 07:57 AM
I pretty much check everything, and I still have the same problem, I would like to try to add a manual entry to the DHCP, our DHCP pool is located on the GW, I was trying to hardcore it but I couldn't could you please let me know the commands that I need to issue
thank you
09-04-2007 10:57 PM
I wouldnt suggest you to play with router. You can easily configure DHCP on CCM for only 1 or few Phones. That will be easy and quick. Use this link to configure DHCP
http://www.windowsnetworking.com/articles_tutorials/w2kdhcpc.html - Then please also select 150 TFTP Server from 2nd last step. Finaly add a reservation in DHCP, after that add a phone in CCM manually. That should work.
10-25-2007 11:17 AM
10-25-2007 11:20 AM
Yes, thank you very much
10-25-2007 11:43 AM
What was the fix??
10-25-2007 01:14 PM
I had to reconfigure the switch port.
re-add it to the voice vlan, that solved the issue
10-25-2007 08:37 PM
Configure DNCP, Add scope of one or two IPs, Conf router Ip in DHCP, then reset the phone hopefully it will be registered, if not then add it manually in CCM - it will be registered.
