ISDN Layer 1 status DEACTIVATED | Transmitter / Receiver error
celestinobuque
Hi everyone,
I have a ISR4431/K9 with one E1 connection to our ISP but it has stopped working.
ISP says that the line is ok, but when I run some commands I see that the line is down, what other kind of tests I can do to verify if the problem is on my side?
show isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/2/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x00000000
Number of L2 Discards = 0, L2 Session ID = 0
Total Allocated ISDN CCBs = 0
show controllers e1 0/2/0
E1 0/2/0 is down
Applique type is Channelized E1 - balanced
Transmitter is sending remote alarm.
Receiver has loss of signal.
alarm-trigger is not set
Give a shut no shut and see if it makes any difference.
Check the physical cable.
Check with ISP what crc4 they use, is it crc4 or no-crc4. Accordingly  check the controller configuration and make changes if required to match the ISP.
Response Signature
Response Signature
Hi @Nithin Eluvathingal
I tried shut no shut and no difference.
I asked the SP to check as they have a converter in the middle, i am wainting. (But they brought a phone tester and they could make calls)
Any other steps to check what is going on?
Check What CRC4 they use. Accordingly make changes on CRC4  configurations.
If you  have a spare Port available on gateway  try on that. ISP provide the service through   a Modem or ONTE ? Also Check the cable connecting Your Gateway.
Response Signature
SP changed the converter and everything is fine now.
VGW-FIG-44-P01-01#show isdn status
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 2
VGW-FIG-44-P01-01#
Thank u for the support
