Issue on changing IP and Hostname in CUCM
Nizam.Ahmed
Hi Expert,
I would like to change IP address of cucm.
What should be the steps to change the IP and Hostname!
Please instruct me.
Thanks & Regards
Nizam
11 Replies 11
Aaron Harrison
Google this:
change ip address cucm 8.6
With your version for specific guidance...
Example: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/install/8_6_1/ipchange/ipchg861.html
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Harrison,
Thanks for your reply.
In the meantime I've tried to change the IP address from the cli. but an error is generating which I've attached for your better understanding.
Please instruct me.
I'm waiting for your reply.
Nizam
Hi Nizam,
This looks to be an issue with the DNS server configuration, please ensure that cucm server info is setup correctly there.
Manish
Hi Manish,
It would helpful for me if you explain.
It is noted that, I've added a new host-name in the DNS of Domain Controller to avoid conflict with the existing host-name. After that while I try to change IP add by cli then the error has been arisen.
Nizam
Did you change the IP address without first changing it in CCMAdmin system/servers menu?
Do you have subscriber servers?
Aaron
Hi Harrison,
Yes I tried to change the IP add without first changing it in CCMAdmin system/servers menu. Should I first change the IP address from CCMAdmin system/servers menu?
Is it the only reason for this type pf error?
Nizam
The procedure is documented for a reason. There are steps you go through make and validate the change, which you have skipped.
I would restore your backup and start again.
Aaron
Would you instruct me the steps.
The cucm version is 10.5
Nizam
Hmm... let me google that for you again:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/install/10_0_1/ipchange/CUCM_BK_C3782AAB_00_change-ipaddress-hostname-100.html
Aaron
Hi Harrison,
Thanks for sharing the link. I could already changed the IP address but another problem has been raised.
While I going to login to cucm an error is prompted is "Database communication error"
What should I do now?
Nizam
Post up 'utils service list' output from the server.
Did you restore and go through the process again? I'm guessing you did not.
