Layer 3 Switch DHCP
galaga
Setting up Microsoft Deployment Server (WDS)
Have Cisco layer 3, users on separate VLAN, DHCP server on same Layer 3 switch
Created new VM Host, connected to trunked port on same switch
WDS server on vlan 15, subnet 192.168.15.0
Users on VLAN 25, 192.168.25.0
PXE deployment not getting IP from DHCP on VLAN 25
IP helper address need to added to DHCP scope ?
BradEast1
Level 3
Level 3
If your clients do not have a DHCP server on their local subnet then you will need a helper address.
Jaime Valencia
You're posting in the Unified Communications Applications area, probably want to move your thread to a relevant area.
java
if this helps, please rate
BradEast1
Level 3
Level 3
Helper address fixed, thanks !
