03-05-2012 10:39 AM - edited 03-19-2019 04:31 AM
Hi, We have site that removed one of two power supplies from 7835 (model number: MCS7835H2-K9-CMA2) running CUCM 7.1.3 after it failed. The LED status now appears normal. My question is, should the LED indicate any type of alarm showing the power is not in a redundant state?
Solved! Go to Solution.
03-05-2012 10:43 AM
If you have a PSU and it doesn't receive power or is faulty, then it's a fault.
If you don't have a secondary PSU, then it's not a fault as nothing is 'broken' - you may simply have not purchased that extra resilience.
Aaron
03-05-2012 10:43 AM
Aaron
03-05-2012 11:15 AM
Makes perfect sense. Thanks!
