Live Record issue on Unity Connection 8.5
Jim Schewe
We have the CoS for Live Record set to a maximum message length of 3600 seconds but our recordings are cutting off at 20 minutes exactly.  We are using a single inbox solution with Exchange 2010 and there are no mailbox size limits on the users. Any ideas?
Manish Gogna
Under Cisco Unity Connection Administration webpage Under System Settings >> Advanced >> Telephony >> Maximum Recording Time in Milliseconds; check if this value is 1200000 (20 minutes); if yes then change this to 3,600,000 milliseconds (1 hour).
Manish
