Mapping attribute otherMobile from Active Directory to AC enterprise
jlcembellin
I have Attendant console 9.1.1.10, callmanager 9.1 and Presence server 9.1.
AC is integrated with Presence server. I have the attribute otherMobile populated in AD. Can I see this attribute in AC contacts?
otherMobile field does not exists in Directory field Mappings configuration page in AC.
Jonathan Schulenberg
CUxAC is getting the directory contents from the CUCM End Users table over AXL (page 366). If you want the field in CUxAC you need to map that attribute to one of the non-custom database fields within CUCM. By default this is mapped to 'mobile' but you can change the attribute mapping on the sync agreement. Unless you integrate CUxAC with LDAP directly (Premium license), you can't grab more than the basic set of fields CUCM stores locally.
Please remember to rate helpful responses and identify helpful or correct answers.
