11-05-2015 03:28 AM - edited 03-19-2019 10:19 AM
Hi all,
I've just installed Mediasense 11 along site CUCM 11.
I have added the 'Record' softkey under connected and applied it to my handset. If the recording option is set to 'Automatic Call Recording Enabled' then when the softkey is pressed I just get a message saying "Recording Already in Progress".
If I switch the recording option to 'Selective Call Recording Enabled' then the softkey appears to work as expected and I can start/stop recording as required.
Is it possible to stop/pause the recording using a softkey when 'Automatic Call Recording Enabled' is set?
Thanks in advance
Matty
Solved! Go to Solution.
11-05-2015 04:05 AM
It is not natively possible to achieve this feature with Media Sense for Automatic Call Recording. However, there are Recording Control APIs that can help here:
Refer to below Developer Guide:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/mediasense/11/Developer_Guide/CUMS_BK_ms-dev-guide-11.pdf
Deepak
- Rate Helpful Posts -
11-05-2015 04:05 AM
Deepak
11-06-2015 01:06 AM
Many thanks for providing the information! Wish I had some time to look into the API stuff!
Matty
11-06-2015 01:09 AM
Never mind :) now since you know it, go through them whenver you get time. Its quite fun to play around with the APIs.
Deepak
