MGCP interaction with CUCM and GW
Rosa Ladeira
Environment:
Cluster --> 2 CUCMs - System version: 7.1.5.10000-12: CM voip1 and CM voip2.  CM voip1 is the publisher and CM voip2 is the subscriber.
GW --> 2 Cisco 2811 - version 12.4(13r)T.
When configuring mgcp GW on CUCM, I verified that Cisco 2811 suports only ISDN.
Currently there are 2 E1 R2 digital circuits connecting PBX and PSTN.
Is there any protocol that enables usage of CUCM controlling GW E1 R2 digital circuits ?
8 Accepted Solutions
Jaime Valencia
Use H323
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Yes, the protocol has nothing to do with those capabilities.
java
java
H323 is a peer to peer protocol, it won't, and will never register with CUCM.
You need to place a call and see what happens or run debugs to make sure it's working properly
Yes, you need to configure the GWs in CUCM, and then in RGs, RLs
java
java
Yes  you are completely true for redundancy , you will have two cisco gateways ( you will configure two route goup each route group has one h323 gateway from your two routers, after that create route list which will includes the two gateways. After that select in each route pattern the route list which you created (which includes the two gateways). For registeation you can use
Router# show dial-peer voice summary
Thank you
please rate
That has nothing to do with registration, that shows you the DP status and operational status.
Which, apparently you haven't configured, so, you need to get all that config.
There are plenty of docs on CCO about H323 config for CUCM.
java
java
Dear Rosa
I do not see any show commands to see if your gateway is registering to your CM , but the command which i typed will show you if your configuration is ok with yur call manager (your dial-peers will show you up and you also show the IP of your call manager which you register on) .Please find the below output
8 voip   up    up            83...            0   syst ipv4:172.16.13.111
As you see this a dial-peer no 8 and destination -pattern os 83... and the call manager is 172.16.13.111 , finally the status is up.
Thank you
Please rate
Hi Rosa,
Let me try and help clarify your doubts on this. From the screenshot you provided, the working gateway shows the ip address correctly while the other gateway doesn't. What this means is that a TCP connection could not be established between the CUCM node and gateway. The reason could be several like firewall, config issues, network issues, interface binding, etc.
Removing and adding the gateway back caused the CUCM and gateway to try and establish a TCP connection again, which was successful this time around and things started working fine. A reset of the gateway from the gateway config page should ideally have done the same thing, so in case you run into this again, try the reset first and then move onto readding the gateway, helps save some time :-)
HTH.
Harmit.
Hi Rosa,
Thanks for the update, glad to hear you tried the reset first. There may have been something hosed up with the H323 stack on CUCM which was preventing the TCP connection to get established, just guessing though. A Packet capture from both GW and CUCM along with detailed CUCM SDI and SDL traces would help get to the root cause if you were to run into this issue ever again. Thanks for the nice rating. See you around!
Harmit.
15 Replies 15
Jaime Valencia
Use H323
java
java
Using h323, CUCM is able to execute all its functions (dial plan,, parking, voice mail....) ?
java
java
I have configure cisco 2811 as an H.323 GW.
CUCM was configured to let 2811 register.
Manual says that "After a gateway is registered with Cisco Unified  Communications Manager, gateway registration status may display in Cisco  Unified Communications Manager Administration as unknown."
Gateways(1 - 1 of 1)  Rows per Page
Find Gateways where endpoints
Device NameSort DescendingDescriptionDevice PoolCalling Search SpaceDevice TypeStatusIP Address
H.323 GatewayXX.XX.XX.XXIMPA Gateway de Voz 1Netadm
H.323 GatewayUnknownXX.XX.XX.XX
So, I can beleive thar GW is resgistered ? Is there any cli cmd on 2811 that confirms regisytation ?
As I have 2 Cisco 2811, I should register the other one Cisco 2811 on this cluster in order to have a backup GW when the first on turns down. Isn't it ?
java
java
Thank you
please rate
Thanks for your answer.
I guess something is wrong.
Command didn't show GW registration.
voipgw1#sh dial-peer voice summary
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT
voipgw1#
java
java
Dear Rosa
Thank you
Please rate
I have configured route group/list.
Both GWs are available on drop-box configuration, but Device->Gateway shows 147.65.21.130 GW IP as Unknown.
Both GWs have the same running config.
Removing and adding 147.65.21.130 GW on Device->Gateway made everything run fine.
I really do not unsderstand why.
Hi Rosa,
HTH.
Harmit.
Harmit removing and adding GW was my last try.
I had reseted and restarted GW many times before removing and adding GW.
I had already restarted firefox browser.
Rosa
Hi Rosa,
Harmit.
