MOH update using CLI on CUCM 10.x
Michel De Feo
Is there a way to update MOH files using the CLI (SSH) , I had a script to do that on Call Manager 4 but I cannot find a way to upload my new MOH files  ?
Any idea welcome.
2 Accepted Solutions
tonyperla
In the newer versions of UCM you will have to upload your MOH files via the GUI.  Essentially going to Media Resources / MOH Audio File Management and uploading from there.  Since in the Linux version's root access is heavily locked down and uploading to a directory via a script is going to be near impossible without that type of access.
Hope this helps
Tony
Please rate helpful posts
Tony
Take a look at these two blogs from Mr. Bell:
http://www.netcraftsmen.net/blogs/entry/live-stream-music-on-hold-and-cisco-uc-on-ucs.html
tonyperla
Hope this helps
Tony
Tony
I know how to do it using the GUI but we use a kind of newsfeed (frequently updated MP3/WAV file)  for MOH and I would like to avoid the manual daily update task.
I guess I will have to find a different way of doing that (may be multicasting from a different source).
I leave the thread open for a few days if somebody has a different idea....
Patrick
Thank you, it was the path I planned to follow (The only one I guess..)
