07-22-2014 06:28 AM - edited 03-19-2019 08:24 AM
Is there a way to update MOH files using the CLI (SSH) , I had a script to do that on Call Manager 4 but I cannot find a way to upload my new MOH files ?
Any idea welcome.
Solved! Go to Solution.
07-22-2014 06:42 AM
In the newer versions of UCM you will have to upload your MOH files via the GUI. Essentially going to Media Resources / MOH Audio File Management and uploading from there. Since in the Linux version's root access is heavily locked down and uploading to a directory via a script is going to be near impossible without that type of access.
Hope this helps
Tony
Please rate helpful posts
07-26-2014 06:07 PM
Take a look at these two blogs from Mr. Bell:
http://www.netcraftsmen.net/blogs/entry/live-stream-music-on-hold-and-cisco-uc-on-ucs.html
07-22-2014 06:42 AM
Hope this helps
Tony
07-22-2014 06:59 AM
I know how to do it using the GUI but we use a kind of newsfeed (frequently updated MP3/WAV file) for MOH and I would like to avoid the manual daily update task.
I guess I will have to find a different way of doing that (may be multicasting from a different source).
I leave the thread open for a few days if somebody has a different idea....
Patrick
07-26-2014 06:07 PM
07-27-2014 11:15 PM
Thank you, it was the path I planned to follow (The only one I guess..)
