06-05-2014 06:52 AM - edited 03-19-2019 08:16 AM
Hi Everyone
I'm looking at the MOH options now and I have a question, I went to the MOH audio source and the MOH server configuration. And I see that each one has an option to allow multicasting, but in the server configuration they have base multi-cast IP and base mutli-cast port. I wanted to know is th IP 239.1.1.1 and what would I put for the port.
Eric
Solved! Go to Solution.
06-05-2014 10:10 AM
You have to put the valid multicast port numbers which include even numbers that range from 16384 to 32767.
Here in your case the MoH server will be streaming a multicast audio source to 239.1.1.1 on RTP port specified.
Refer below link for MOH Configuration and more detail,
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/3_1_2/ccmcfg/b04moh.html#wp1035654
Venkatesh
06-05-2014 10:11 AM
Please check Table 1 of the following link for multicast addressing based on incrementing IP and port number
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/feature/guide/MOH_srst.html
Manish
06-05-2014 10:10 AM
Venkatesh
06-05-2014 10:11 AM
Manish
