More MOH Questions
scooter817
Level 2
Level 2
Hi Everyone
I'm looking at the MOH options now and I have a question, I went to the MOH audio source and the MOH server configuration. And I see that each one has an option to allow multicasting, but in the server configuration they have base multi-cast IP and base mutli-cast port. I wanted to know is th IP 239.1.1.1 and what would I put for the port.
Eric
2 Accepted Solutions
You have to put the valid multicast port numbers which include even numbers that range from 16384 to 32767.
Here in your case the MoH server will be streaming a multicast audio source to 239.1.1.1 on RTP port specified.
Refer below link for MOH Configuration and more detail,
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/3_1_2/ccmcfg/b04moh.html#wp1035654
Venkatesh
Manish Gogna
Please check Table 1 of the following link for multicast addressing based on incrementing IP and port number
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cusrst/feature/guide/MOH_srst.html
Manish
Venkatesh
Manish Gogna
Manish
