Move Unity Connection Mailbox to Another Cluster
Jacob Webb
Okay, so I have existing users on Unity connection 8.5, but the entire office is moving to another region where I have a completely separate 10.5 cluster.  Is there a way for me to migrate those users to the new cluster while retaining the voice mail and recorded names?
These users are only a subset of the users on the 8.5 cluster.  Not every mail box should be migrated.
Terry Cheema
Jacob,
Please refer to below guide, you can use COBRAS, to import/export the users along with messages read/unread. But I think it will do export/import all, have a read through below migration guide
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/design/guide/10xcucdgx/10xcucdg037.html#pgfId-1059352
-Terry
Please rate all helpful posts
6 Replies 6
Terry Cheema
Jacob,
-Terry
Please refer to below link for download and videos on how to use this tool.
http://www.ciscounitytools.com/Applications/General/COBRAS/COBRAS.html
-Terry
Thanks Terry.  I'll try that tonight.
No worries, please let me know how you go.
-Terry
Please rate all helpful posts and if you have no other queries please mark thread as answered.
Hi Terry, thanks for the help and sorry for the late reply.
I used the COBRAS tool to move a single user successfully.  The only thing I would add to what you said is that when you export you get everyone's recordings, but on import you can choose a single user, a list from csv, or all users from the database.
Thanks for the feedback Jacob.
-Terry
