MWI problem
hantonov42
I have Unity 4.0.5 (running on windows 2003 SP1) working with exchange 2003 SP2. I have no problems with the voice mails, but the MWI is not working. In the eventlog of the Unity server I can see the following message "An attempt to access the Primary Exchange Mailbox Store by AvNotifierMgr via MAPI has failed. The MAPI subsystem return the following error: The attempt to log on to the Microsoft Exchange Server computer has failed.. "
I run the permission wizard again and still have the same problem. Any thoughts?
thisisshanky
Level 11
Level 11
Can you attach a event viewer log (app log evt)
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
hantonov42
I found the problems with the service permissions. It looks like the permission wizard didn't do the job. After changing it manually MWI started to work.
diarmuidhaugh
Do you remember what permissions you had to set manually. I am having the same issue. Only AvNotifierMgr service won't start so MWI is not working. I get the same error:
I ran the permissions wizard but it didn't work. I am running Unity on 2003 SP1 abd Exchange on 2003 SP1.
I will run the permissions wizard again.
