No Phone status/BLF displayed in ARC Console (CUBACS) for extension mobility users
k-renouard
No Phone status/BLF displayed in ARC Attendant Console (CUBACS) for extension mobility users
Call Manager 7.1(3)
CUBACS/CUBAC 3.1.5
I do see the phone status on the attendant console for fixed configuration phones but not the users with extension mobility. Not even the phone with a red cross through it.
bijin bharathan
Did you get solution for this issue?.
Bill19795_2
I don't think CUBAC supports EM users.
This is from the CUxAC Design Guide.
Extension Mobility
Be aware that Extension Mobility is NOT supported for CUxAC client IP Phones. Therefore, Console Attendant cannot have Extension Mobility configured on their handset.
Extension Mobility is supported in the Attendant BLF (Busy Lamp Field) and the status of an extension mobility user is only displayed if the user is "logged in". In order for Line State information to be retrieved for a logged in EM User, the Device Profile Directory Number and the End User EM configuration should have the "Allow control of Device from CTI" check box enabled.
Is the user logged in? Can you see the status of the phone that they are logging into when they are not logged in?
I run into the same issue. Has this been resolved now?
As mentioned at design guide:
"Extension Mobility is supported in the Attendant BLF (Busy Lamp Field) and the status of an extension mobility user is only displayed if the user is "logged in". In order for Line State information to be retrieved for a logged in EM User, the Device Profile Directory Number and the End User EM configuration should have the "Allow control of Device from CTI" check box enabled."
I've given all users at end user configuration the right "Allow Control of Device from CTI" and also at Directory Number configuration page.
However Extension mobilty user appear to be unknown for BLF state at operator console.
kindly regards,
Bernhard
