Outgoing call not working in voip gateway
dgonzalez1
Hello, I'm troubleshuting a call in a voip gateway which is falling with 500-Internal Server Error message.
The call is made to number 0145 from extension 21999. The call is release stright away with no delay. I have an outgoing dial-peer which matches this number:
dial-peer voice 2006 pots
trunkgroup M-MARINGA-VIVO
description ## Salientes Otros Servicios#
preference 1
destination-pattern 01[1-80].
direct-inward-dial
forward-digits 3
Is in the traces that this dial-peer is selected but then an error came up (which I'm not undestanding) and message 500 is sent. This is attached trace 145-Nok1.txt
I tried adding an addicional dial-peer which matches the calling number more accurately:
dial-peer voice 2060 pots
description ## Salientes 0145 ##
preference 1
destination-pattern 0145$
direct-inward-dial
forward-digits 3
In this case a call back tone is heard by a couple of seconds and then the call is release anyway also with 500-Internal Server Error message. In the traces I see that new dial-peer 2060 is selected first but then old dial-peer 2006 is reselected. This is attached trace 145-Nok2.txt
I tried then shuting down the old dial-peer 2006 and now the call is again release stright away, as in the first case, with no call back tone, despite I see in the trace that new dial-peer 2060 is selected. This is attached trace 145-Nok3.txt
I'm also ataching the complete config of the router.
(I had to compress the trace files because they wren't recognized as plain text and were removed.)
IOS version is:
RO-MATRIZ-MARINGA#show version
Cisco IOS XE Software, Version 16.03.07
Cisco IOS Software [Denali], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.3.7, RELEASE SOFTWARE (fc4)
If someone know what could be happening here I will appreciate any help.
Thank you in advance.
14 Replies 14
Thank you Colling. I made a "debug vtsp all" and I see that all digits are being sent to the pstn and then a release occurs, I guess from the pstn. Is that what "Release Source=Called Party-PSTN" means:
//72996756/E0390C800001/VTSP:(0/1/0:0):2:1:3/vtsp_process_event:
[state:S_SETUP_REQ_PROC, event:E_TSP_DISCONNECT_IND]
027256: Dec 30 17:21:15.085: //72996756/E0390C800001/VTSP:(0/1/0:0):2:1:3/act_setup_pend_release_ind:
Cause Value=0
027257: Dec 30 17:21:15.085: //72996756/E0390C800001/VTSP:(0/1/0:0):2:1:3/vtsp_ring_noan_timer_stop:
Timer Stop Time=3920538644
027258: Dec 30 17:21:15.086: //72996756/E0390C800001/VTSP:(0/1/0:0):2:1:3/vtsp_cc_call_disconnected:
027259: Dec 30 17:21:15.086: //72996756/E0390C800001/VTSP:(0/1/0:0):2:1:3/vtsp_cc_call_disconnected:
Cause Value=0
027260: Dec 30 17:21:15.086: //72996756/E0390C800001/VTSP:(0/1/0:0):2:1:3/vtsp_set_release_source:
Release Direction=PSTN, Release Source=Called Party-PSTN
Thanks.
Thank you.
dgonzalez1
By the way, I made a "debug vtsp all" and I see that all digits are sent to the pstn, after what a release occurs, apparently from the pstn. Is that what "Release Source=Called Party-PSTN" means?:
027255: Dec 30 17:21:15.085: //72996756/E0390C800001/VTSP:(0/1/0:0):2:1:3/vtsp_process_event:
Cause Value=0
Cause Value=0
Thank you.
dgonzalez1
By the way, I made a "debug vtsp all" and see that all digits are sent to the pstn, after what a release occurs, apparently from the pstn. Is that what "Release Direction=PSTN, Release Source=Called Party-PSTN" means?
Thank you.
None of these dial peers has a port or session destination, so they can not be used in the outbound direction. Please have a look at this excellent document for details on how to configure call routing in IOS.
https://www.cisco.com/c/en/us/support/docs/voice/ip-telephony-voice-over-ip-voip/211306-In-Depth-Explanation-of-Cisco-IOS-and-IO.html
Response Signature
Thank you Roger, but a successull call to number 0190 is going out through dial-peer 2005 and both are configured the same:
dial-peer voice 2005 pots
description ## Salientes Emergencias ##
preference 1
destination-pattern 019.$
direct-inward-dial
forward-digits 3
preference 1
direct-inward-dial
forward-digits 3
Also all local, national calls, etc, are working fine.
Thanks.
Please show the output of debug voip ccapi inout of a successful call that uses these dial peers. As said none of these can work as outbound with the configuration shared.
Response Signature
Sure, here you are.
Thank you for your time.
For some reason the file can not be opened on a mobile device. Can you please repost it as a txt file?
Response Signature
Ok, I did so because otherway the file is removed because it's nor recognized as plain text:
I'll paste it here:
RO-MATRIZ-MARINGA#
RO-MATRIZ-MARINGA#debug voip ccapi inout
voip ccapi inout debugging is on
RO-MATRIZ-MARINGA#debug ccsip messages
SIP Call messages tracing is enabled
RO-MATRIZ-MARINGA#ter mon
027501: Dec 30 18:52:58.137: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0190@172.23.80.12:5060 SIP/2.0
Via: SIP/2.0/UDP 172.23.80.38:5060;branch=z9hG4bK19bbc5b30c22fc9
From: <sip:21999@172.23.80.38>;tag=129457360~9544df53-d8df-44ee-8445-a1593fdd0243-77158469
To: <sip:0190@172.23.80.12>
Date: Thu, 30 Dec 2021 18:52:58 GMT
Call-ID: b33f2680-1ce1000a-15b5bce-265017ac@172.23.80.38
Supported: timer,resource-priority,replaces
Min-SE: 600
User-Agent: Cisco-CUCM11.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:172.23.80.38:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP;x-cisco-qos-tcl=true
Session-ID: 4a01a51700105000a0002a3197743d2a;remote=00000000000000000000000000000000
Cisco-Guid: 3007260288-0000065536-0000088779-0642783148
Session-Expires: 1800
P-Asserted-Identity: <sip:21999@172.23.80.38>
Remote-Party-ID: <sip:21999@172.23.80.38>;party=calling;screen=yes;privacy=off
Contact: <sip:21999@172.23.80.38:5060>;video;audio;+u.sip!devicename.ccm.cisco.com="BOTJPNAVARRO";bfcp
Max-Forwards: 13
Content-Length: 0
027502: Dec 30 18:52:58.139: //-1/B33F26800001/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=21999
----- ccCallInfo IE subfields -----
cisco-ani=21999
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=0190
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFFFFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
027503: Dec 30 18:52:58.140: //-1/B33F26800001/CCAPI/cc_api_call_setup_ind_common:
Interface=0x7FB161A4CFF8, Call Info(
Calling Number=21999,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=0190(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=1000, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=72999626
027504: Dec 30 18:52:58.140: //-1/B33F26800001/CCAPI/ccCheckClipClir:
In: Calling Number=21999(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
027505: Dec 30 18:52:58.140: //-1/B33F26800001/CCAPI/ccCheckClipClir:
Out: Calling Number=21999(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
027506: Dec 30 18:52:58.140: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
027507: Dec 30 18:52:58.140: :cc_get_feature_vsa malloc success
027508: Dec 30 18:52:58.140: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
027509: Dec 30 18:52:58.140: cc_get_feature_vsa count is 1
027510: Dec 30 18:52:58.140: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
027511: Dec 30 18:52:58.140: :FEATURE_VSA attributes are: feature_name:0,feature_time:140399896222980,feature_id:862707
027512: Dec 30 18:52:58.141: //72999626/B33F26800001/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=21999(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=0190(TON=Unknown, NPI=Unknown))
027513: Dec 30 18:52:58.141: //72999626/B33F26800001/CCAPI/cc_process_call_setup_ind:
Event=0x7FB165F31180
027514: Dec 30 18:52:58.141: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 0190
027515: Dec 30 18:52:58.142: //72999626/B33F26800001/CCAPI/ccCallSetContext:
Context=0x7FB16CA661E8
027516: Dec 30 18:52:58.142: //72999626/B33F26800001/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 72999626 with tag 1000 to app "_ManagedAppProcess_Default"
027517: Dec 30 18:52:58.142: //72999626/B33F26800001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-16.3.7
Session-ID: 00000000000000000000000000000000;remote=4a01a51700105000a0002a3197743d2a
Content-Length: 0
027518: Dec 30 18:52:58.143: //72999626/B33F26800001/CCAPI/ccCallProceeding:
027519: Dec 30 18:52:58.143: //72999626/B33F26800001/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=2005, Params=0x7FB16B1EB6E8, Progress Indication=NULL(0)
027520: Dec 30 18:52:58.143: //72999626/B33F26800001/CCAPI/cc_fill_tg_params:
Not a cic call
027521: Dec 30 18:52:58.143: //72999626/B33F26800001/CCAPI/ccCallSetupRequest:
Trunk Group Select Interface Success;
Interface=0x7FB169F6C628, Selected Interface=1, Selected DSL=-1
027522: Dec 30 18:52:58.144: //72999626/B33F26800001/CCAPI/ccCheckClipClir:
027523: Dec 30 18:52:58.144: //72999626/B33F26800001/CCAPI/ccCheckClipClir:
027524: Dec 30 18:52:58.144: //72999626/B33F26800001/CCAPI/ccCallSetupRequest:
Destination Pattern=019.$, Called Number=0190, Digit Strip=TRUE
027525: Dec 30 18:52:58.144: //72999626/B33F26800001/CCAPI/ccCallSetupRequest:
Redirect Number=, Display Info=
Account Number=21999, Final Destination Flag=TRUE,
Guid=B33F2680-0001-0000-0001-5ACB265017AC, Outgoing Dial-peer=2005
027526: Dec 30 18:52:58.144: //72999626/B33F26800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=21999
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=0190
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
027527: Dec 30 18:52:58.145: //72999626/B33F26800001/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x7FB169F6C628, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=21999,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=0190(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2005, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=M-MARINGA-VIVO, tg_label_flag=2, Application Call Id=)
027528: Dec 30 18:52:58.145: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
027529: Dec 30 18:52:58.145: :cc_get_feature_vsa malloc success
027530: Dec 30 18:52:58.145: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
027531: Dec 30 18:52:58.145: cc_get_feature_vsa count is 2
027532: Dec 30 18:52:58.145: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
027533: Dec 30 18:52:58.145: :FEATURE_VSA attributes are: feature_name:0,feature_time:140399896235972,feature_id:862708
027534: Dec 30 18:52:58.145: //72999627/B33F26800001/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
027535: Dec 30 18:52:58.145: //72999626/B33F26800001/CCAPI/ccCallSetupRequest:
RO-MATRIZ-MARINGA#Trunk Group Call Setting;
Call Entry(Retry Count=0, Voice Class Cause Code=0)
027536: Dec 30 18:52:58.145: //72999627/B33F26800001/CCAPI/ccCallSetContext:
Context=0x7FB16B1EB668
027537: Dec 30 18:52:58.145: //72999626/B33F26800001/CCAPI/ccSaveDialpeerTag:
027538: Dec 30 18:52:58.146: //72999626/B33F26800001/CCAPI/cc_api_modify_tgt_cid_call_active_record:
Target Trkgrp Route Label=M-MARINGA-VIVO, tg_label_flag=TRUE, Call Id=0x459E2CA
027539: Dec 30 18:52:58.600: //72999627/B33F26800001/CCAPI/cc_api_call_proceeding:
Interface=0x7FB169F6C628, Progress Indication=NULL(0)
027540: Dec 30 18:52:58.600: //72999627/B33F26800001/CCAPI/ccSetCallGCID:
Update GCID [FFFFFFFF8A22961B-68D811EC-FFFFFFFFBE66F36B-FFFFFFFFBDC2265E] with [FFFFFFFF8A22961B-68D811EC-FFFFFFFFBE66F36B-FFFFFFFFBDC2265E]
027541: Dec 30 18:52:59.153: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
027549: Dec 30 18:53:01.334: //72999627/B33F26800001/CCAPI/cc_api_call_alert:
Interface=0x7FB169F6C628, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
027550: Dec 30 18:53:01.334: //72999627/B33F26800001/CCAPI/cc_api_call_alert:
Call Entry(Retry Count=0, Responsed=TRUE)
027551: Dec 30 18:53:01.334: //72999627/B33F26800001/CCAPI/ccSetCallGCID:
027552: Dec 30 18:53:01.334: //72999626/B33F26800001/CCAPI/ccCallAlert:
027553: Dec 30 18:53:01.334: //72999626/B33F26800001/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
027554: Dec 30 18:53:01.335: //72999626/B33F26800001/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFFFFFFFFFF, callID1=0x459E2CA, gcid=8A22961B-68D811EC-BE66F36B-BDC2265E, tag=0x0)
027555: Dec 30 18:53:01.335: //72999627/B33F26800001/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFFFFFFFFFF, callID2=0x459E2CB, gcid=8A22961B-68D811EC-BE66F36B-BDC2265E, tag=0x0)
027556: Dec 30 18:53:01.335: //72999626/B33F26800001/CCAPI/ccConferenceCreate:
Conference Id=0xFFFFFFFFFFFFFFFF, Call Id1=72999626, Call Id2=72999627, Tag=0x0
027557: Dec 30 18:53:01.335: //72999626/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
027558: Dec 30 18:53:01.335: cc_api_get_xcode_stream : 4999
027559: Dec 30 18:53:01.335: //72999626/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
027560: Dec 30 18:53:01.335: cc_api_get_xcode_stream : 4999
027561: Dec 30 18:53:01.335: //72999626/B33F26800001/CCAPI/cc_api_bridge_done:
Conference Id=0x35151, Source Interface=0x7FB161A4CFF8, Source Call Id=72999626,
Destination Call Id=72999627, Disposition=0x0, Tag=0x0
027562: Dec 30 18:53:01.335: //72999627/B33F26800001/CCAPI/cc_api_bridge_done:
Conference Id=0x35151, Source Interface=0x7FB169F6C628, Source Call Id=72999627,
Destination Call Id=72999626, Disposition=0x0, Tag=0xFFFFFFFFFFFFFFFF
027563: Dec 30 18:53:01.335: //72999626/B33F26800001/CCAPI/cc_generic_bridge_done:
027564: Dec 30 18:53:01.336: //72999626/B33F26800001/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x35151, Destination Call Id=72999627)
027565: Dec 30 18:53:01.336: //72999627/B33F26800001/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x35151, Destination Call Id=72999626)
027566: Dec 30 18:53:01.336: //72999626/B33F26800001/CCAPI/ccConferenceCreate:
027567: Dec 30 18:53:01.336: confID:0x35151; callEntry1 callID1:0x459E2CA, type:3; callEntry2 callID2:0x459E2CB, type:6
027568: Dec 30 18:53:01.336: //72999627/B33F26800001/CCAPI/ccSetCallGCID:
027569: Dec 30 18:53:01.336: //72999627/B33F26800001/CCAPI/cc_api_caps_ind:
027570: Dec 30 18:53:01.336: voice_rtp_nse_payload 0, voice_rtp_sse_payload 118 voice_sprt_payload 120
027571: Dec 30 18:53:01.336: //72999627/B33F26800001/CCAPI/cc_api_caps_ind:
027572: Dec 30 18:53:01.336: sprt_latency 200, sprt_retries 12
027573: Dec 30 18:53:01.336: //72999627/B33F26800001/CCAPI/cc_api_caps_ind:
Destination Interface=0x7FB161A4CFF8, Destination Call Id=72999626, Source Call Id=72999627,
Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
027574: Dec 30 18:53:01.336: //72999627/B33F26800001/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
027575: Dec 30 18:53:01.337: //72999626/B33F26800001/CCAPI/cc_api_caps_ind:
027576: Dec 30 18:53:01.337: voice_rtp_nse_payload 100, voice_rtp_sse_payload 118 voice_sprt_payload 120
027577: Dec 30 18:53:01.337: //72999626/B33F26800001/CCAPI/cc_api_caps_ind:
027578: Dec 30 18:53:01.337: sprt_latency 200, sprt_retries 12
027579: Dec 30 18:53:01.337: //72999626/B33F26800001/CCAPI/cc_api_caps_ind:
Destination Interface=0x7FB169F6C628, Destination Call Id=72999627, Source Call Id=72999626,
Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
027580: Dec 30 18:53:01.337: //72999626/B33F26800001/CCAPI/cc_api_caps_ind:
027581: Dec 30 18:53:01.337: //72999626/B33F26800001/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=8006)
027582: Dec 30 18:53:01.337: //72999627/B33F26800001/CCAPI/cc_api_caps_ack:
027583: Dec 30 18:53:01.337: //72999626/B33F26800001/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=72999626
027584: Dec 30 18:53:01.339: //72999626/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
027585: Dec 30 18:53:01.339: cc_api_get_xcode_stream : 4999
027586: Dec 30 18:53:01.339: //72999626/B33F26800001/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x35151, Call Id1=72999626, Call Id2=72999627
027587: Dec 30 18:53:01.341: //72999627/B33F26800001/CCAPI/cc_api_voice_mode_event:
Call Id=72999627
027588: Dec 30 18:53:01.341: //72999627/B33F26800001/CCAPI/cc_api_voice_mode_event:
Call Entry(Context=0x7FB16B1EB668)
027589: Dec 30 18:53:01.341: //72999626/B33F26800001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
To: <sip:0190@172.23.80.12>;tag=2128E688-BE1
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Remote-Party-ID: <sip:190@172.23.80.12>;party=called;screen=no;privacy=off
Contact: <sip:0190@172.23.80.12:5060>
Supported: sdp-anat
Session-ID: c595b13b7558505dbf1e4bacc3a79924;remote=4a01a51700105000a0002a3197743d2a
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 444
v=0
o=CiscoSystemsSIP-GW-UserAgent 95 7050 IN IP4 172.23.80.12
s=SIP Call
c=IN IP4 172.23.80.12
t=0 0
m=audio 20232 RTP/AVP 0 100 101
a=rtpmap:0 PCMU/8000
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194,200-202
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
a=X-sqn:0
a=X-cap: 1 audio RTP/AVP 100
a=X-cpar: a=rtpmap:100 X-NSE/8000
a=X-cpar: a=fmtp:100 192-194,200-202
a=X-cap: 2 image udptl t38
027590: Dec 30 18:53:01.342: //72999627/B33F26800001/CCAPI/ccSetCallGCID:
027591: Dec 30 18:53:01.342: //72999627/B33F26800001/CCAPI/ccSetCallGCID:
RO-MATRIZ-MARINGA#Update GCID [FFFFFFFF8A22961B-68D811EC-FFFFFFFFBE66F36B-FFFFFFFFBDC2265E] with [FFFFFFFF8A22961B-68D811EC-FFFFFFFFBE66F36B-FFFFFFFFBDC2265E]
027592: Dec 30 18:53:01.342: //72999627/B33F26800001/CCAPI/ccSetCallGCID:
027593: Dec 30 18:53:02.438: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
RO-MATRIZ-MARINGA#
027595: Dec 30 18:53:09.480: //72999627/B33F26800001/CCAPI/cc_api_call_connected:
Interface=0x7FB169F6C628, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
Connection Handle=0
027596: Dec 30 18:53:09.480: //72999627/B33F26800001/CCAPI/cc_api_call_connected:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
027597: Dec 30 18:53:09.480: //72999627/B33F26800001/CCAPI/ccSetCallGCID:
027598: Dec 30 18:53:09.480: //72999626/B33F26800001/CCAPI/ccCallConnect:
Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
027599: Dec 30 18:53:09.481: //72999626/B33F26800001/CCAPI/ccCallConnect:
Call Entry(Connected=TRUE, Responsed=TRUE)
027600: Dec 30 18:53:09.481: //72999626/B33F26800001/CCAPI/ccCallNotify:
027601: Dec 30 18:53:09.482: //72999626/B33F26800001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Supported: replaces
Supported: sdp-anat
Require: timer
Session-Expires: 1800;refresher=uac
Supported: timer
Content-Length: 444
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=X-sqn:0
027602: Dec 30 18:53:09.496: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0190@172.23.80.12:5060 SIP/2.0
Via: SIP/2.0/UDP 172.23.80.38:5060;branch=z9hG4bK19bbc5e2c53d4cf
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: 4a01a51700105000a0002a3197743d2a;remote=c595b13b7558505dbf1e4bacc3a79924
Content-Length: 414
v=0
o=CiscoSystemsCCM-SIP 129457360 1 IN IP4 172.23.80.38
s=SIP Call
c=IN IP4 172.20.101.26
b=TIAS:64000
b=AS:64
t=0 0
a=cisco-mari:v1
a=cisco-mari-rate
m=audio 49730 RTP/AVP 0 101
a=extmap:14/sendrecv http://protocols.cisco.com/timestamp#100us
a=fmtp:101 0-15
a=trafficclass:conversational.audio.aq:admitted
a=rtcp:49731 IN IP4 172.20.101.26
027603: Dec 30 18:53:09.497: //72999626/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
027604: Dec 30 18:53:09.497: cc_api_get_xcode_stream : 4999
027605: Dec 30 18:53:09.497: //72999626/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
027606: Dec 30 18:53:09.497: cc_api_get_xcode_stream : 4999
027607: Dec 30 18:53:09.497: //72999626/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
027608: Dec 30 18:53:09.498: cc_api_get_xcode_stream : 4999
027609: Dec 30 18:53:09.498: //72999626/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
027610: Dec 30 18:53:09.498: cc_api_get_xcode_stream : 4999
027611: Dec 30 18:53:09.498: //72999626/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
027612: Dec 30 18:53:09.498: cc_api_get_xcode_stream : 4999
027613: Dec 30 18:53:09.498: //72999626/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
027614: Dec 30 18:53:09.498: cc_api_get_xcode_stream : 4999
027615: Dec 30 18:53:09.498: //72999626/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
027616: Dec 30 18:53:09.498: cc_api_get_xcode_stream : 4999
027617: Dec 30 18:53:09.498: //72999626/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
027618: Dec 30 18:53:09.498: cc_api_get_xcode_stream : 4999
027619: Dec 30 18:53:09.498: //72999626/B33F26800001/CCAPI/cc_api_caps_ind:
027620: Dec 30 18:53:09.498: voice_rtp_nse_payload 0, voice_rtp_sse_payload 118 voice_sprt_payload 120
027621: Dec 30 18:53:09.498: //72999626/B33F26800001/CCAPI/cc_api_caps_ind:
027622: Dec 30 18:53:09.498: sprt_latency 200, sprt_retries 12
027623: Dec 30 18:53:09.499: //72999626/B33F26800001/CCAPI/cc_api_caps_ind:
027624: Dec 30 18:53:09.499: //72999626/B33F26800001/CCAPI/cc_api_caps_ind:
027625: Dec 30 18:53:09.499: //72999626/B33F26800001/CCAPI/cc_api_caps_ack:
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=6971)
027626: Dec 30 18:53:09.499: //72999627/B33F26800001/CCAPI/cc_api_caps_ack:
027627: Dec 30 18:53:09.501: //72999627/B33F26800001/CCAPI/cc_api_voice_mode_event:
RO-MATRIZ-MARINGA#Call Id=72999627
027628: Dec 30 18:53:09.501: //72999627/B33F26800001/CCAPI/cc_api_voice_mode_event:
RO-MATRIZ-MARINGA#
027629: Dec 30 18:53:11.946: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
027654: Dec 30 18:53:31.951: //72999627/B33F26800001/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Sum Network, Params=0x0, Call Id=72999627
027655: Dec 30 18:53:31.951: //72999626/B33F26800001/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x7FB161A4CFF8, Call Id=72999626
027656: Dec 30 18:53:31.951: //72999626/B33F26800001/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
027657: Dec 30 18:53:31.952: //72999626/B33F26800001/CCAPI/ccConferenceDestroy:
Conference Id=0x35151, Tag=0x0
027658: Dec 30 18:53:31.952: //72999626/B33F26800001/CCAPI/ccConferenceDestroy:
027659: Dec 30 18:53:31.952: confID:0x35151; callEntry1 callID1:0x459E2CA, type:3; callEntry2 callID2:0x459E2CB, type:6
027660: Dec 30 18:53:31.952: //72999626/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
027661: Dec 30 18:53:31.952: cc_api_get_xcode_stream : 4999
027662: Dec 30 18:53:31.953: //72999627/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
027663: Dec 30 18:53:31.953: cc_api_get_xcode_stream : 4999
027664: Dec 30 18:53:31.953: //72999626/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
027665: Dec 30 18:53:31.953: cc_api_get_xcode_stream : 4999
027666: Dec 30 18:53:31.953: //72999626/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
027667: Dec 30 18:53:31.953: cc_api_get_xcode_stream : 4999
027668: Dec 30 18:53:31.953: //72999626/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
027669: Dec 30 18:53:31.953: cc_api_get_xcode_stream : 4999
027670: Dec 30 18:53:31.953: //72999626/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
027671: Dec 30 18:53:31.953: cc_api_get_xcode_stream : 4999
027672: Dec 30 18:53:31.953: //72999626/B33F26800001/CCAPI/cc_api_bridge_drop_done:
027673: Dec 30 18:53:31.953: //72999627/B33F26800001/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=72999626, Disposition=0x0, Tag=0x0
027674: Dec 30 18:53:31.953: //72999626/B33F26800001/CCAPI/cc_generic_bridge_done:
027675: Dec 30 18:53:31.955: //72999626/B33F26800001/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
027676: Dec 30 18:53:31.955: //72999626/B33F26800001/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
027677: Dec 30 18:53:31.955: //72999627/B33F26800001/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
027678: Dec 30 18:53:31.955: //72999627/B33F26800001/CCAPI/ccCallDisconnect:
027679: Dec 30 18:53:31.955: //72999627/B33F26800001/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
027680: Dec 30 18:53:31.998: //72999626/B33F26800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7FB161A4CFF8, Tag=0x0, Call Id=72999626,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
027681: Dec 30 18:53:31.998: //72999626/B33F26800001/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
027682: Dec 30 18:53:31.998: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
027683: Dec 30 18:53:31.998: :cc_free_feature_vsa freeing 7FB165F0DCF8
027684: Dec 30 18:53:31.998: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
027685: Dec 30 18:53:31.998: vsacount in free is 1
027686: Dec 30 18:53:31.999: //72999626/B33F26800001/SIP/Msg/ccsipDisplayMsg:
Sent:
RO-MATRIZ-MARINGA#SIP/2.0 200 OK
Via: SIP/2.0/UDP 172.23.80.38:5060;branch=z9hG4bK19bbc67492313ed
Date: Thu, 30 Dec 2021 18:53:31 GMT
CSeq: 102 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=1122,OS=224400,PR=1093,OR=218600,PL=0,JI=5,LA=0,DU=22
Session-ID: c595b13b7558505dbf1e4bacc3a79924;remote=c595b13b7558505dbf1e4bacc3a79924
Content-Length: 0
027687: Dec 30 18:53:32.311: //72999627/B33F26800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7FB169F6C628, Tag=0x0, Call Id=72999627,
027688: Dec 30 18:53:32.311: //72999627/B33F26800001/CCAPI/cc_api_call_disconnect_done:
tg for this call is M-MARINGA-VIVO success/fail is 1
027689: Dec 30 18:53:32.311: //72999627/B33F26800001/CCAPI/cc_api_call_disconnect_done:
027690: Dec 30 18:53:32.311: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
027691: Dec 30 18:53:32.311: :cc_free_feature_vsa freeing 7FB165F10FB8
027692: Dec 30 18:53:32.311: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
RO-MATRIZ-MARINGA#
027693: Dec 30 18:53:32.311: vsacount in free is 0
RO-MATRIZ-MARINGA#und
Thank you
For a short while there was a post with the output of the debug directly in the post, but now it’s oddly enough gone. Nevertheless I saw that I overlooked the fact that there is a trunk group on the dial peers. As such they do work as outbound dial peers. Do you have the output of the same debug for a failed call?
Response Signature
Yes, I don't know why some post are deleted.
This is the failing trace:
RO-MATRIZ-MARINGA#
025850: Dec 30 12:42:42.391: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0145@172.23.80.12:5060 SIP/2.0
Via: SIP/2.0/UDP 172.23.80.38:5060;branch=z9hG4bK19ba5a323813f04
From: <sip:21999@172.23.80.38>;tag=129436899~9544df53-d8df-44ee-8445-a1593fdd0243-77157907
To: <sip:0145@172.23.80.12>
Date: Thu, 30 Dec 2021 12:42:42 GMT
Call-ID: f97a9280-1cd1a942-15b48fb-265017ac@172.23.80.38
Min-SE: 600
CSeq: 101 INVITE
Expires: 180
Session-ID: 1340511100105000a0002a3197743d2a;remote=00000000000000000000000000000000
Cisco-Guid: 4185559680-0000065536-0000088737-0642783148
Max-Forwards: 13
Content-Length: 0
025851: Dec 30 12:42:42.393: //-1/F97A92800001/CCAPI/cc_api_display_ie_subfields:
cisco-ani=21999
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=0145
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
025852: Dec 30 12:42:42.394: //-1/F97A92800001/CCAPI/cc_api_call_setup_ind_common:
Called Number=0145(TON=Unknown, NPI=Unknown),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=72988421
025853: Dec 30 12:42:42.394: //-1/F97A92800001/CCAPI/ccCheckClipClir:
025854: Dec 30 12:42:42.394: //-1/F97A92800001/CCAPI/ccCheckClipClir:
025855: Dec 30 12:42:42.394: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
025856: Dec 30 12:42:42.394: :cc_get_feature_vsa malloc success
025857: Dec 30 12:42:42.394: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
025858: Dec 30 12:42:42.394: cc_get_feature_vsa count is 1
025859: Dec 30 12:42:42.394: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
025860: Dec 30 12:42:42.394: :FEATURE_VSA attributes are: feature_name:0,feature_time:140399896233732,feature_id:862237
025861: Dec 30 12:42:42.394: //72988421/F97A92800001/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Called Number=0145(TON=Unknown, NPI=Unknown))
025862: Dec 30 12:42:42.395: //72988421/F97A92800001/CCAPI/cc_process_call_setup_ind:
Event=0x7FB165F2CD40
025863: Dec 30 12:42:42.395: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 0145
025864: Dec 30 12:42:42.395: //72988421/F97A92800001/CCAPI/ccCallSetContext:
Context=0x7FB16B470F80
025865: Dec 30 12:42:42.395: //72988421/F97A92800001/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 72988421 with tag 1000 to app "_ManagedAppProcess_Default"
025866: Dec 30 12:42:42.395: //72988421/F97A92800001/CCAPI/ccCallProceeding:
025867: Dec 30 12:42:42.396: //72988421/F97A92800001/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=2006, Params=0x7FB16CA56670, Progress Indication=NULL(0)
025868: Dec 30 12:42:42.396: //72988421/F97A92800001/CCAPI/cc_fill_tg_params:
Not a cic call
025869: Dec 30 12:42:42.396: //72988421/F97A92800001/CCAPI/ccCallSetupRequest:
025870: Dec 30 12:42:42.396: //72988421/F97A92800001/CCAPI/ccCheckClipClir:
025871: Dec 30 12:42:42.397: //72988421/F97A92800001/CCAPI/ccCheckClipClir:
025872: Dec 30 12:42:42.397: //72988421/F97A92800001/CCAPI/ccCallSetupRequest:
Destination Pattern=01[1-80]., Called Number=0145, Digit Strip=TRUE
025873: Dec 30 12:42:42.397: //72988421/F97A92800001/CCAPI/ccCallSetupRequest:
Guid=F97A9280-0001-0000-0001-5AA1265017AC, Outgoing Dial-peer=2006
025874: Dec 30 12:42:42.397: //72988421/F97A92800001/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=21999
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=0145
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
025875: Dec 30 12:42:42.398: //72988421/F97A92800001/CCAPI/ccIFCallSetupRequestPrivate:
Called Number=0145(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2006, Call Count On=FALSE,
025876: Dec 30 12:42:42.398: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
025877: Dec 30 12:42:42.398: :cc_get_feature_vsa malloc success
025878: Dec 30 12:42:42.398: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
025879: Dec 30 12:42:42.398: cc_get_feature_vsa count is 2
025880: Dec 30 12:42:42.398: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
025881: Dec 30 12:42:42.398: :FEATURE_VSA attributes are: feature_name:0,feature_time:140399896223876,feature_id:862238
025882: Dec 30 12:42:42.398: //72988422/F97A92800001/CCAPI/ccIFCallSetupRequestPrivate:
025883: Dec 30 12:42:42.398: //72988421/F97A92800001/CCAPI/ccCallSetupRequest:
025884: Dec 30 12:42:42.398: //72988422/F97A92800001/CCAPI/ccCallSetContext:
Context=0x7FB16CA565F0
025885: Dec 30 12:42:42.398: //72988421/F97A92800001/CCAPI/ccSaveDialpeerTag:
025886: Dec 30 12:42:42.399: //72988421/F97A92800001/CCAPI/cc_api_modify_tgt_cid_call_active_record:
Target Trkgrp Route Label=M-MARINGA-VIVO, tg_label_flag=TRUE, Call Id=0x459B705
025887: Dec 30 12:42:42.400: //72988421/F97A92800001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Session-ID: 00000000000000000000000000000000;remote=1340511100105000a0002a3197743d2a
Content-Length: 0
025890: Dec 30 12:42:42.850: //72988422/F97A92800001/CCAPI/cc_api_call_proceeding:
025891: Dec 30 12:42:42.850: //72988422/F97A92800001/CCAPI/ccSetCallGCID:
025896: Dec 30 12:42:46.575: //72988422/F97A92800001/CCAPI/cc_api_call_disconnected:
Cause Value=0, Interface=0x7FB169F6C628, Call Id=72988422
025897: Dec 30 12:42:46.575: //72988422/F97A92800001/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=0, Retry Count=0)
025898: Dec 30 12:42:46.575: //72988422/F97A92800001/CCAPI/ccSetCallGCID:
Update GCID [FFFFFFFFD084C361-68A411EC-FFFFFFFF90D5F36B-FFFFFFFFBDC2265E] with [FFFFFFFFD084C361-68A411EC-FFFFFFFF90D5F36B-FFFFFFFFBDC2265E]
025899: Dec 30 12:42:46.575: //72988421/F97A92800001/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
025900: Dec 30 12:42:46.576: //72988422/F97A92800001/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=72988422
025901: Dec 30 12:42:46.576: //72988422/F97A92800001/CCAPI/ccCallDisconnect:
Cause Value=0, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
RO-MATRIZ-MARINGA#
025902: Dec 30 12:42:46.576: //72988422/F97A92800001/CCAPI/ccCallDisconnect:
Cause Value=0, Call Entry(Responsed=TRUE, Cause Value=0)
025903: Dec 30 12:42:46.576: //72988422/F97A92800001/CCAPI/cc_api_get_transfer_info:
025904: Dec 30 12:42:46.578: //72988422/F97A92800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7FB169F6C628, Tag=0x0, Call Id=72988422,
Call Entry(Disconnect Cause=0, Voice Class Cause Code=0, Retry Count=0)
025905: Dec 30 12:42:46.578: //72988422/F97A92800001/CCAPI/cc_api_call_disconnect_done:
tg for this call is M-MARINGA-VIVO success/fail is 0
025906: Dec 30 12:42:46.579: //72988422/F97A92800001/CCAPI/cc_api_call_disconnect_done:
025907: Dec 30 12:42:46.579: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
025908: Dec 30 12:42:46.579: :cc_free_feature_vsa freeing 7FB165F0E078
025909: Dec 30 12:42:46.579: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
025910: Dec 30 12:42:46.579: vsacount in free is 1
025911: Dec 30 12:42:46.579: //72988421/F97A92800001/CCAPI/ccCallDisconnect:
025912: Dec 30 12:42:46.579: //72988421/F97A92800001/CCAPI/ccCallDisconnect:
025913: Dec 30 12:42:46.580: //72988421/F97A92800001/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error
To: <sip:0145@172.23.80.12>;tag=1FD5EE22-12DF
CSeq: 101 INVITE
Session-ID: 1340511100105000a0002a3197743d2a;remote=cf8207ed9165505888b281689b8b9dd1
Content-Length: 0
025914: Dec 30 12:42:46.582: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0145@172.23.80.12:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
025915: Dec 30 12:42:46.583: //72988421/F97A92800001/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7FB161A4CFF8, Tag=0x0, Call Id=72988421,
025916: Dec 30 12:42:46.583: //72988421/F97A92800001/CCAPI/cc_api_call_disconnect_done:
025917: Dec 30 12:42:46.583: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
025918: Dec 30 12:42:46.583: :cc_free_feature_vsa freeing 7FB165F106F8
025919: Dec 30 12:42:46.583: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
025920: Dec 30 12:42:46.583: vsacount in free is 0
RO-MATRIZ-MARINGA#
RO-MATRIZ-MARINGA#show dialplan number 0145
Macro Exp.: 0145
VoiceEncapPeer2006
peer type = voice, system default peer = FALSE, information type = voice,
description = `## Salientes Otros Servicios#',
tag = 2006, destination-pattern = `01[1-80].',
voice reg type = 0, corresponding tag = 0,
allow watch = FALSE
answer-address = `', preference=1,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
rtp-ssrc mux = system
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 2006, Admin state is up, Operation state is up,
Outbound state is up,
incoming called-number = `',
connections/maximum = 0/unlimited,
DTMF Relay = disabled,
URI classes:
Destination =
Destination route-string = None
huntstop = disabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
Translation profile (Incoming):
Translation profile (Outgoing):
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 0 oldAddrFamily 0
mailbox selection policy: none
trunk-group:
id = `M-MARINGA-VIVO', preference = `'
type = pots, prefix = `',
forward-digits 3
session-target = `', voice-port = `',
direct-inward-dial = enabled,
digit_strip = enabled,
register E.164 number with H323 GK and/or SIP Registrar = TRUE
fax rate = system, payload size = 20 bytes
supported-language = ''
preemption level = `routine'
bandwidth:
maximum = 64 KBits/sec, minimum = 64 KBits/sec
voice class called-number:
inbound = `', outbound = `'
dial tone generation after remote onhook = enabled
mobility=0, snr=, snr_noan=, snr_delay=0, snr_timeout=0
snr calling-number local=disabled, snr ring-stop=disabled, snr answer-too-soon timer=0
Time elapsed since last clearing of voice call statistics never
Connect Time = 207486, Charged Units = 0,
Successful Calls = 17, Failed Calls = 71, Incomplete Calls = 0
Accepted Calls = 0, Refused Calls = 0,
Last Disconnect Cause is "0 ",
Last Disconnect Text is "",
Last Setup Time = 3913055617.
Last Disconnect Time = 3913056070.
Matched: 0145 Digits: 3 Matched pattern: Preference: 1
Target:
RO-MATRIZ-MARINGA#
I posted it, but it was deleted again.
It is in a zip file in the original post, but you can't open it.
