Outgoing call showing Anonymous on cucm
akram.root
Level 4
Level 4
Hello all
I hope you are doing well.
I have a ptoblem with a line when i make a call with this line it showing Anonymous calls .
In the trace SIP on the RTMT : sip: Anonymous@anonymous
The call work fine but it show anonymous call on calling number .
How can i solve it ?
Could you help me please .
Best regards
15 Replies 15
b.winter
If the other party sees the calling number as anonymous, then you probably hit a translation or route pattern in CUCM, which restricts the calling number.
So, check the call routing in CUCM, which translation and / or route patterns are used for dialing out and then, check the config of those patterns.
Thank you for your reply ,
The call routing in CUCM, which translation and / or route patterns  is correct .
If i use another SDA by another phone the number show correctly
Best regards
What is a SDA? Never heard that acronym before.
Response Signature
SDA is a DID  : direct inward dialing   , SDA is a nomination in french.
Have you compared the callrouting / traces / config of a working and the non-working phone / directory number?
Have you pinned down already, where the restriction is taking place? Does CUCM do it, or it is happening on the GW / CUBE?
Have you compared the callrouting / traces / config of a working and the non-working phone / directory number? yes they have the same config .
And what about the call routing? Are they using the same translation patterns, route patterns, CSS, partition, ...?
Don't let everything come out of your nose ...
What about looking at traces? Have you done that?
What about the other questions?
How should we help you, if you only throw small pieces of information around you?
The problem is solved after changed the css by the phone thank you for your collaboration
Best regards
I thought you said that they had the same configuration, “yes they have the same config”, based on your last reply I get that this was inaccurate as you now state “The problem is solved after changed the css by the phone”.
For any future post that you do please take your time to actually check your configuration before your summarily answer questions from members that tries to help you. We’re doing this on our own time and would appreciate accurate response on questions we ask.
Response Signature
Hi, please don't forget to mark your question as solved.
Maybe you have this set on the SIP profile that the phone uses?
Response Signature
How can i find those parametres ? are not in the Sip profile
Best regards
It is in the SIP profile under Device > Device Settings > SIP Profile > select the SIP profile that the device uses.
Response Signature
I use a Standard SIP Profile in this phone ,
I can't find this  external presentation number on sip profile
For your information i use CUCM version 10.5
Best regards
