Problem with notofication voice message by email
akram.root
Level 4
Level 4
Hello ,
I have a cisco unity connection 11.5 all work fine , the problem that i have when i sent a voice message via ip phone to another IP phone , the voice message  appear and work on ip phone , but it not appear on voice mail .
Could you help me please
Best regards
Akram
6 Replies 6
What do you mean by “but it not appear on voice mail”? The message you see, by the MWI, and can listen to on the phone is in your voice mail system. Do you mean that the voice message does not appear in your mail client?
Response Signature
Hi ,
Yes , the voice message does not appear in  mail client.
Best regards
Have you configured CUC to integrate to your mail system?
Response Signature
Yes , it's configured and tested already
Have you?
1. Associated a UM service with the user? (User > Edit > Unified Messaging Accounts)
2. Ensured that the SMTP proxy address matches the end-user's email address. If AD integrated and the mail address is correct, we check the box "Generate SMTP Proxy Address From Corporate Email Address".  Alternatively you can click into the Edit User Basics >  Unified Messaging Accounts  > Edit Unified Messaging Account  (Service Name) and manually set the SMTP address
3 From the same menu above, test the UM account for the user.  Any issues should give you the info you need to troubleshoot further.
Response Signature
Do messages from one IP phone to another appear with a "From:" of an actual person? This can happen in a UM configuration. If so, are there any filter rules that are moving the email from a particular sender to a folder?
