PVDM4 max sessions & config
markbialik
We have an ISR4331 with a PVDM4-128 on the motherboard.  I'm new to the voice world, and have been tasked with finding out of the current PVDM4-128 is sufficient if we upgrade the total number of SIP paths we have with our provider.  I inherited the configuration and am having a hard time understanding how to configure the 'max sessions' parameter if I need to.
Currently, we can have 90 concurrent SIP sessions with our provider.  The DSP portion of our config looks like this:
voice-card 0/4
dsp services dspfarm
no watchdog
dspfarm profile 2 transcode
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 64
associate application SCCP
dspfarm profile 1 mtp
codec g729r8
maximum sessions software 160
When I try to change the value of 'max sessions' under profile 2, 64 is the highest I can select.  That's my first question: why not 128?  I've read about the different complexities and I'm wondering if it has to do with the order of the codecs specified?  If we only configured G711 (or another low complexity codec), would it then allow me to choose 128?
We don't do any conferenceing in-house; we dial a 3rd party provider when we want to have conference calls (unless I'm completely misunderstanding what conferencing is all about).
If it matters, we do have CUCM, two AVG's for faxing, and a seperate VG connected to a PRI.  The 4331 CUBE is our SIP router to the provider.
I'm having a hard time understanding how we could ever have more than 64 SIP calls with the 'max sessions' setting the way it is.  A local resource told me that the PVDM4 is only used if transcoding needs to take place so we should be fine with the PVDM4-128 if we increase our SIP sessions from 90 to say, 110.  I guess I'm having a hard time grasping this... I assumed some sort of transcoding is always going to take place, whether it's low, medium, or high complexity.
Sorry if these are stupid questions.... just trying to get my ahead around it all.
Thanks for any help.
13 Replies 13
R0g22
In a CUBE setup, you don't need any DSP's. DSP are required for IP to Analog or TDM termination and/or vice-versa. A CUBE is an IP to IP gateway. So need for any DSP's to make your calls work. Your SIP calls/sessions will be solely dependent upon the router platform that you are using.
A transcoder is required if you have a codec mismatch. Let's say one IP leg is using G711ulaw while the second IP leg is going to use G729, the calls will not be able to complete until and unless a transcoder is invoked between the two legs. The transcoder will be invoked either by CUCM (SCCP) or can be invoked by CUBE itself (LTI).
So if you carefully design your network and make sure their are no codec mismatches then you would potentially not require any DSP/PVDM's on your router.
Nipun,
Thank you for your reply.  That's interesting.  I know we're using the 4331 as a CUBE (I have the paper licenses that say CUBE for our 90 SIP sessions).  I have no idea why the consultant who placed the order said we needed to upgrade the PVDM4 to a -128, then.  Maybe this CUBE is doing more than a traditional CUBE?  I will post a sanitized config below.  Is there any transcoding between the router and CUCM?  I also notice there is a config description for XCODE to UCCX.  Thanks again.
voice service voip
 ip address trusted list
  ipv4 x.x.x.x 255.255.255.255
 address-hiding
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol pass-through g711ulaw
 sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  rel1xx supported "rel100"
  session refresh
  header-passing
  error-passthru
  asserted-id pai
  localhost dns:y.y.y.y
  asymmetric payload full
  early-offer forced
  midcall-signaling passthru
  privacy-policy passthru
  g729 annexb-all
  pass-thru subscribe-notify-events all
voice class uri FromCUCM sip
 host x.x.x.x
 host ipv4:y.y.y.y
 host ipv4:z.z.z.z
voice class uri FromProvider sip
 host a.a.a.a
 host ipv4:b.b.b.b
voice class codec 100
 codec preference 4 g711ulaw
 codec preference 6 g729r8
voice class h323 1
  h225 timeout tcp establish 3
  h225 timeout setup 3
voice class sip-profiles 101
 request ANY sip-header Cisco-Guid remove
 response ANY sip-header Cisco-Guid remove
 request ANY sip-header User-Agent remove
 response ANY sip-header User-Agent remove
 request INVITE sip-header P-Asserted-Identity modify "(<.*:.*)(@.*)" "<sip:123456789@sip-provider.com>"
voice-card 0/4
 no watchdog
mgcp
mgcp modem passthrough voip mode nse
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0/0
sccp ccm d.d.d.d identifier 11 version 7.0
sccp ccm e.e.e.e identifier 10 version 7.0
sccp
sccp ccm group 10
 description XCODE for UCCX
 associate ccm 11 priority 1
 associate ccm 10 priority 2
 associate profile 2 register 03-XCODE
 associate profile 1 register 03-MTP
no ccm-manager fax protocol cisco
 codec g729r8
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 maximum sessions 64
 codec g729r8
dial-peer voice 90 voip
 description Inbound SIP from Call Manager
 session protocol sipv2
 session target dns:our-call-manager-server-IP
 incoming called-number .
 incoming uri via FromCUCM
 voice-class codec 100
 voice-class sip options-keepalive
 voice-class sip bind control source-interface GigabitEthernet0/0/0
 voice-class sip bind media source-interface GigabitEthernet0/0/0
 dtmf-relay rtp-nte
 ip qos dscp cs3 signaling
 no vad
dial-peer voice 91 voip
 description Inbound SIP from SIP Provider
 rtp payload-type cisco-codec-fax-ind 127
 rtp payload-type nte 96
 session target sip-server
 incoming uri via FromSIPprovider
 voice-class sip bind control source-interface Loopback0
 voice-class sip bind media source-interface Loopback0
 dtmf-relay rtp-nte
 no vad
dial-peer voice 100 voip
 description Outbound LD and Toll Free Calls to SIP Provider
 destination-pattern 1[2-9]..[2-9]......
 session transport udp
 voice-class sip profiles 101
 dtmf-relay rtp-nte
 no vad
dial-peer voice 101 voip
 description Outbound International Calls to SIP Provider
 destination-pattern 011T
 dtmf-relay rtp-nte
 no vad
dial-peer voice 888 voip
 description Outbound to CUCM
 destination-pattern 888.......
 session target dns:our-cucm-server
 dtmf-relay rtp-nte
 no vad
dial-peer voice 800 voip
 destination-pattern 800.......
 dtmf-relay rtp-nte
 no vad
gateway
 media-inactivity-criteria rtp
 timer receive-rtp 86400
Your cucm pointing dial-peers are not explicitly configured for a codec, hence will default to g729. I am assuming this is a remote site so due to wan/bw consumption it would be that way.
Your UCCX must be doing G711ulaw. To compensate for the codec mismatch, you would need a transcoder.
R0g22
To add to my post above, you can -
1. Check region settings on cucm for CTI pointing to UCCX. What is it set to ?
2. If you have access to UCCX, go to system > system parameter > codec.
See there what is it set to.
Neither cucm nor ccx can do transcoding natively. DSP resources on a IOS router will always be required for transcoding.
Hi Nipun,
I checked the regions and device pools.  All (but one) are set to the default:
Default Use System Default (Factory Default low loss) 64 kbps (G.722, G.711) 384 kbps 2147483647 kbps
There is one entry:
G729 Everywhere Use System Default (Factory Default low loss) 8 kbps (G.729) None
2147483647 kbps
In UCCX, the information you requested is Codec parameter is set to G711.  Thank you.
So that explains what I wrote above and your query for the need for a transcoder.
You cannot design a SIP deployment for specific codec as most carriers will offer different codecs and for some calls single codec under specific conditions. For example ITSP1 customer A calls customerB (same ITSP) and customer A offers only G729 on outbound calls via EO, the ITSP will then relay only G729 to customerB as ITSPs will never do transcoding on their side (too expensive), thus customerB may have assumed they get all calls as G711 (ask for), but they are never guaranteed that and may require transcoders based on their region configuration and/or applications the calls go to (i.e. CCX defined with G711).
So, you ALWAYS need to account for some transcoding on ALL SIP deployments.
Hi Chris,
Thanks for chiming-in.  Every little piece of knowledge helps, and hopefully others reading this thread.  I guess this answers the question of why the PVDM4 was specd-out to begin with.  That makes me feel a lit better.  So, I'm working through what Nipun said: In a CUBE setup, you don't need any DSP's" and what you said.  I think, in fairness, Nipun did not have my full config when he answered the initial question.  So, I am assuming with the CUCM, UCCX and SIP all in the mix, there definitely seems to be a need for transcoding.  I'm still a little unsure about why the CUBE won't let me set a max sessions above 64 with a -128 PVDM4.
The router does the calculation of how many sessions are available based on codec complexities, as different codecs require different amount of PVDMs.  What codes do you have configured under the dspfarm?
It's in one of the posts above, along with my theorizing that the max value had to do with defined codecs in the farm, but here it is again:
 codec g729r8
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 maximum sessions 64
 codec g729r8
I'm guessing by allowing the above codecs, the CUBE does an internal calculation of low/medium/high complexity codecs and decides on 64 as the best value?  Thanks.
remove following codecs from your transcoder profile as you dont need them:
 codec g729ar8
 codec g729abr8
Thanks, Chris.  Interesting.  OK.  I will try to get a downtime/change-window to do this today.  Just for my own knowledge (and others who may be in the same boat), how do you know these are un-needed codecs?  Are they legacy and not in use anymore?  Do you think removing these may help bump that max sessions higher than 64?  I'm not sure what increments these are typically given in.  Thank you for your time.
Hello Mark, I'm curious if you found out why these codecs weren't needed? Are they legacy and not in use anymore? Also, once you removed them, did it help to bump that max sessions higher than 64?
