Router 4331 with UCS-E issue with CIPC
polxpol
How to solve this issue that all of my cipc are getting same ip address. Example: I add multiple CIPC and all of their ip address is 172.16.6.30
Could you provide more details about your setup and clarify where you are adding the CIPC? I don’t see any configuration related to registering the CIPC in the shared text files.
Response Signature
On the CUCM
I assume there is no firewall in between. If that’s the case, I’ll consider restarting the Cisco RIS Data Collector and checking the CUCM database to ensure everything is normal.
Response Signature
In your first post you wrote that all CIPC has IP 172.16.6.30, but in the picture it shows that they have 172.16.6.10. Which is it?
As @Nithin Eluvathingal wrote there is nothing in the shared config that pertains to CIPC or to passing out IPs to any clients.
Response Signature
