RTMT reporting on active PRI
Amafsha1
Level 2
Level 2
Hello, we currently have about 20 PRI circuits from our ISP scattered throughout our branches.  Where in RMTM could I get a report from how often and how much we use these 20 PRI ciruits?  A report that can span a couple weeks if possible.  Thank you
R0g22
If these end points are MGCP controlled, RTMT monitoring is possible. It won't be possible to monitor the d-channel and/or b-channel with H.323 or SIP.
Yes, they are MGCP controlled.  How do I get reporting on all active PRIs and how many channels they are all using together total?
How many channel used together for 20 PRI's would be 480 including d-channels taken the fact that these are T1's. For E1's, the number will be higher.
Reporting would be CAR/CDR but if you are trying to actively monitor the calls, b-channel etc. you can use Perfmon in RTMT.
Another possibility is using the Call Detail Record Analysis and Reporting Tool (CAR).
"Generate Gateway Utilization Reports"
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/11_5_1/car/CUCM_BK_C72B9385_00_cdr-analysis-and-reporting_1151/CUCM_BK_C72B9385_00_cdr-analysis-and-reporting_1151_chapter_010011.html#CUCM_TK_G3937293_00
There is additional setup such as activating the CAR Web Service, generating CDRs, and configuring gateway capacity. But the CAR tool was intended to generate exactly the kind of report you are looking for.
