ā02-15-2019 09:32 AM - edited ā03-19-2019 01:41 PM
I am running Callmanager 11.5. Some users are having issues that when they login to the Self Care Portal they get a artificer error "The server could not prove that it is X.X.X.X. Its security certificate is from Subscriber X.X.X.X. this may be caused by a misconfiguration. The people getting this error show the subscriber address in the browser url field. Other people are not having any issues. The certificates are signed by third party but have been fine other than this weird issue. Nothing in the logs seem abnormal. Anyone else have seen this? Any thoughts? All the DNS info is okay.
Solved! Go to Solution.
ā02-15-2019 09:40 AM
You need to use the CN or any of the SAN entries, if they use the IP that is expected.
ā02-19-2019 08:47 AM
Jamie as always you are correct. Customer was using ip and the cucm name without domain. Then two subscribers were not in DNS. I was trying to find a document that explained this but I didn't find anything.
Thank you very much. Take care
