Set Dial_Peer Destination pattern to 5 digits
Tashi BDFCL
Hello Everyone,
I have an issue regarding setting of dial-peer destination pattern to 5 digits. In my organization we have IP Phone 7906 and 6921. All the IP Phone dial numbers are of four digits (1001, 1002, 1003, 1004, 2013, 2045..and so on).
Now i want to have the digits to five i.e. 10011, 10023, 30321, 80322.. and so on. I have tried to set the dial-peer in following manner to achieve 5 digits of IP Phone number.
Here is my configuration
dial-peer voice 2018 pots
destination-pattern 8....
port 0/0/0
forward-digits 4
In the above configuration i have set destination-pattern to 8.... which means 8 with four digits (5 in total).
Is the configuration correct? Am i missing further configuration to achieve 5 digits of IP Phone number? Please help me.
7 Replies 7
Chris Deren
Sure as long as you need to strip the 8 before sending the call to the phone, the question here is what is the call flow as this is a POTS dial peer which would imply you are sending the call out to PSTN.  What system are you using?
Chris
Nadeem Ahmed
Hello
By default in pots dial-peer it's strip the qualified digit match
port 0/0/0
forward-digits 4
As per your dial-peer configured you have destination pattern 8...., so here it will strip the 8 and as a matter of fact of fact you have forward digit 4 configured under this dial-peer it will send only 4 digit .
If you want achieve and to send 5 digit the. Configured either forward digit all or no digit strip
Br, Nadeem Please rate all useful post.
Thanks for your response. If i make the forward digit to all or not digit strip, will it effect the current working IP Phones? Since i have other configuration as follows :
control-plane
voice-port 0/0/0
connection plar opx 1001
caller-id enable
voice-port 0/0/1
connection plar opx 1002
caller-id enable
voice-port 0/0/2
caller-id enable
voice-port 0/0/3
caller-id enable
mgcp profile default
dial-peer voice 1990 pots
destination-pattern 90.......
port 0/0/0
forward-digits 8
dial-peer voice 1991 pots
destination-pattern 9[2-6].....
port 0/0/0
forward-digits 6
dial-peer voice 1992 pots
destination-pattern 91.......
port 0/0/0
forward-digits 8
dial-peer voice 1993 pots
destination-pattern 97.......
port 0/0/0
--More-- forward-digits 8
dial-peer voice 1994 pots
port 0/0/1
forward-digits 8
dial-peer voice 1995 pots
port 0/0/1
forward-digits 6
dial-peer voice 1996 pots
port 0/0/1
forward-digits 8
dial-peer voice 1997 pots
port 0/0/1
forward-digits 8
dial-peer voice 1998 pots
port 0/0/2
forward-digits 8
dial-peer voice 1999 pots
port 0/0/2
forward-digits 6
dial-peer voice 2000 pots
port 0/0/2
forward-digits 8
dial-peer voice 2001 pots
port 0/0/2
forward-digits 8
dial-peer voice 2002 pots
port 0/0/3
forward-digits 8
dial-peer voice 2003 pots
port 0/0/3
forward-digits 6
--More-- dial-peer voice 2004 pots
port 0/0/3
forward-digits 8
dial-peer voice 2005 pots
port 0/0/3
forward-digits 8
dial-peer voice 2006 pots
destination-pattern 81..
port 0/0/0
forward-digits 3
dial-peer voice 2007 pots
port 0/0/1
forward-digits 3
dial-peer voice 2008 pots
port 0/0/2
forward-digits 3
dial-peer voice 2009 pots
port 0/0/3
forward-digits 3
dial-peer voice 2010 pots
destination-pattern 95.....
port 0/0/0
forward-digits 6
dial-peer voice 2011 pots
port 0/0/1
forward-digits 6
dial-peer voice 2012 pots
port 0/0/2
forward-digits 6
dial-peer voice 2013 pots
port 0/0/3
forward-digits 6
dial-peer voice 2014 pots
destination-pattern 98.....
--More-- port 0/0/0
forward-digits 6
dial-peer voice 2015 pots
port 0/0/1
forward-digits 6
dial-peer voice 2016 pots
port 0/0/2
forward-digits 6
dial-peer voice 2017 pots
port 0/0/3
forward-digits 6
The line highlighted on BOLD uses 4 digits i.e. 2014, 7777,9999, 8001 and so on. Can you please give me some configuration example to achieve 5 digits.
no It won't, If you could provide us the exact call-flow and topology with requirement/issue you are facing i might be able to given some concrete solutions, however the one which i have given example it does not have any impact it will send only 5 digit to the destination that's it.
Br,
Nadeem
Sorry Nadeem, i didnt get you. Are you asking me to send my CCME router configuration? If yes then please find below:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.01.22 17:23:21 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 42559 bytes
! Last configuration change at 17:02:31 UTC Wed Jan 22 2014
! NVRAM config last updated at 17:02:32 UTC Wed Jan 22 2014
version 15.1
service password-encryption
hostname ROUTERCCME
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$oAsG$UbrxBP0dpE.h3RBBp7WFt1
no aaa new-model
clock timezone UTC 6 6
no ipv6 cef
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.11.2 192.168.11.20
ip dhcp pool IPTELEPHONES
network 192.168.11.0 255.255.255.0
option 150 ip 192.168.11.1
default-router 192.168.11.1
ip domain name yourdomain.com
crypto pki trustpoint TP-self-signed-1859121955
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1859121955
revocation-check none
rsakeypair TP-self-signed-1859121955
--More-- !
crypto pki trustpoint TP-self-signed-2189781093
subject-name cn=IOS-Self-Signed-Certificate-2189781093
rsakeypair TP-self-signed-2189781093
crypto pki certificate chain TP-self-signed-1859121955
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31383539 31323139 3535301E 170D3132 31323135 30343034
33395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 38353931
32313935 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100B906 FB652ED9 BD551AD0 69725244 F33BB857 54C2F40B 213D854B 9012AE9B
E3B97C50 73F732F3 8437E7D2 D8A2BD69 129EF339 BAC197F2 6C2D7845 03D0FE53
8CEB792C 23592F49 1ACBF9F0 0BE293F9 27F85572 58FC2D0D 3AD69181 B31B5018
05AD5448 D019F625 C7BE11F7 E4A5B335 4EA557D4 331331FE 9382C335 CBEE7558
2A4D0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14FE54A5 2918FF1E 55C69F1F 5F5176EC 62F7F6A0 85301D06
03551D0E 04160414 FE54A529 18FF1E55 C69F1F5F 5176EC62 F7F6A085 300D0609
2A864886 F70D0101 05050003 81810094 79481070 567946DC A43F56D8 CCFC2F19
30E7E026 E7AE9120 9D64B469 9FCDB942 731E3F42 C51BFF12 8E87273B C515E9A9
BC604B43 07CB6461 D8245059 604D5242 93B7338A E02B3431 94370F40 ED45A2BD
48C08475 1BEFA7BD 2FADD309 369BEC2C 7EFE9B8D 976CA6A7 95CD3F3D 03D252D2
2DBF4071 4ED187B5 13085802 5373E3
quit
crypto pki certificate chain TP-self-signed-2189781093
voice-card 0
license udi pid C3900-SPE150/K9 sn FOC16484F21
license accept end user agreement
license boot module c3900 technology-package datak9
hw-module pvdm 0/0
username tashi password 7 08354D5D011057474359
redundancy
--More-- !
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Link to CORESWITCH 1
ip address 192.168.11.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 192.168.11.10
nls resp-timeout 1
cpd cr-id 1
snmp-server community Bdbl2288 RO
snmp-server host 192.168.1.98 Bdbl2288
tftp-server flash:CP7902040000SCCP040701A.sbin
tftp-server flash:CP7905040000SCCP040701A.sbin
tftp-server flash:CP7912040000SCCP040701A.sbin
tftp-server flash:P00303020214.bin
tftp-server flash:P00305000301.sbn
tftp-server flash:P00403020214.bin
tftp-server flash:S00103020002.bin
--More-- tftp-server flash:cmterm_7920.4.0-01-08.bin
tftp-server flash:apps11.1-0-2-12.sbn
tftp-server flash:cnu11.3-0-3-12.sbn
tftp-server flash:cvm11.7-2-2-12.sbn
tftp-server flash:dsp11.1-0-2-12.sbn
tftp-server flash:jar11.7-2-2-12.sbn
tftp-server flash:SCCP11.7-2-3S.loads
tftp-server flash:term06.default.loads
tftp-server flash:term11.default.loads
control-plane
voice-port 0/0/0
caller-id enable
voice-port 0/0/1
caller-id enable
voice-port 0/0/2
caller-id enable
voice-port 0/0/3
caller-id enable
port 0/0/0
forward-digits 8
port 0/0/0
forward-digits 6
port 0/0/0
forward-digits 8
port 0/0/0
port 0/0/1
forward-digits 8
port 0/0/1
forward-digits 6
port 0/0/1
forward-digits 8
port 0/0/1
forward-digits 8
port 0/0/2
forward-digits 8
port 0/0/2
forward-digits 6
port 0/0/2
forward-digits 8
port 0/0/2
forward-digits 8
port 0/0/3
forward-digits 8
port 0/0/3
forward-digits 6
port 0/0/3
forward-digits 8
port 0/0/3
forward-digits 8
port 0/0/0
forward-digits 3
port 0/0/1
forward-digits 3
port 0/0/2
forward-digits 3
port 0/0/3
forward-digits 3
port 0/0/0
forward-digits 6
port 0/0/1
forward-digits 6
port 0/0/2
forward-digits 6
port 0/0/3
forward-digits 6
--More-- port 0/0/0
forward-digits 6
port 0/0/1
forward-digits 6
port 0/0/2
forward-digits 6
port 0/0/3
forward-digits 6
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-ephones 240
max-dn 600
ip source-address 192.168.11.1 port 2000
system message BDBL
cnf-file location flash:
load 7906 SCCP11.7-2-3S
time-zone 40
time-format 24
date-format dd-mm-yy
max-conferences 12 gain -6
moh music-on-hold.au
multicast moh 239.7.17.57 port 2000
transfer-system full-consult
login timeout 5
after-hours block pattern 1 90.......
after-hours block pattern 2 97.......
after-hours block pattern 3 91.......
after-hours block pattern 4 95.....
after-hours block pattern 5 98.....
after-hours day Sun 00:00 23:59
after-hours day Mon 00:00 23:59
after-hours day Tue 00:00 23:59
after-hours day Wed 00:00 23:59
after-hours day Thu 00:00 23:59
after-hours day Fri 00:00 23:59
--More-- after-hours day Sat 00:00 23:59
create cnf-files version-stamp 7960 Jan 21 2014 09:58:21
ephone-dn 1 dual-line
number 1001 secondary 324687
name Operator
call-forward busy 1002
call-forward noan 1002 timeout 10
huntstop channel
no huntstop
ephone-dn 2 dual-line
number 1002 secondary 333865
name operator
huntstop channel
no huntstop
ephone-dn 3 dual-line
ephone-dn 4 dual-line
number 1004
name Operator
ephone-dn 5 dual-line
number 8001
name Thimphu Main Branch
ephone-dn 6 dual-line
number 8002
name Thimphu Branch
huntstop channel
no huntstop
ephone-dn 7 dual-line
number 8003
name Paro Branch
huntstop channel
no huntstop
ephone-dn 8 dual-line
number 8004
name Wanduephodrang Branch
huntstop channel
no huntstop
--More--
ROUTER_CCME#exit
Hello Tashi
Actually I wanted to know the call-flow Topology
when A Phone calling Phone B what all entities are involved ? where are these phones register?
Br,
Nadeem
Basically the question comes down to this:
Do you realize that changing what/how many digits you send for calling from your ISR, will have implications on what the other side will receive and how to handle the calls accordingly????
Are you responsible for the other... ISR?? CUCM?? whatever it is you're going to call, and have you also planned on how to adjust the configuration there???
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
