SIP Trunk to CUCM
Areyouserious
Hi all.
I'm trying to connect a SIP trunk line to my Cisco call manager.
up until now I've been using Asterisk to connect a few 7940s.
I'm not sure if the sip trunking set up with asterisk is the same with CUCM, as I'm using a Chan_SIP trunk.
I've been having a play around and some googling but no luck.
What is confusing me the most is where exactly in CUCM do you configure the
SIP Registration string, account number and password/pin credentials to connect to the sip trunk?
Just wondering if anyone could point me in the right direction.
Thanks.
19 Replies 19
Yeah... get some sleep :-)
Drop the leading 9.
Consider whether you need a 0 for national access (it looks like you do based on this : http://en.wikipedia.org/wiki/Telephone_numbers_in_Australia#Central_East_region_.2802.29 ... and we do in the UK and most other places)
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
I'm beginning to think that maybe CUBE might not be installed on this router.
All it has is the Advanced ip services image on it.
Might explain why some commands that I use to try and configure cube do not work.
Pls check the following;
https://supportforums.cisco.com/discussion/11035831/cube-licensing-29xx39xx-routers
https://supportforums.cisco.com/document/69976/frequently-asked-questions-cisco-unified-border-element-cube
You don't 'install' CUBE, it's built in to IOS. You don't even actually license it, you just purchase a license for the right to use it.
Aaron
Ahh I see so if a 2811 has advanced ip services on it then cube is running without need for activation or a licence key?
