Small deployment
jamil.saif
Greetings,
I have a small deployment for IP Telephony Solution, 150 Users (Phones)
Do I need a cluster server that is for call manager express (CME) or the router ISR 4431 can handle calls?
also, what is the recommendation for PBX? is there ant alternative from cisco?
2 Accepted Solutions
CME runs on a router, like the ISR4K. So there is no concept for cluster with this. It would provide the services that a PBX would do.
Response Signature
If you need to do clustering go with a CUCM model. AS @Roger  Mentioned,CME will be running on Cisco router.
For licensing and other BOQ reach out to a local Cisco partner who is good in voice. Below mentioned are some documents which will be helpful for you.
https://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-communications-manager-express/datasheet-c78-744069.html
https://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-express-version-14-0/model.html
Response Signature
6 Replies 6
Response Signature
Thank you for your kind reply
Would you please share a reference for deployment, requirements, licensing, etc..
Appreciate your help
All that is available at cisco.com. Go there and if you don’t find what you need please get back to this post.
Response Signature
I am already there... since last few days, scattered, old "out dated" artices, etc...
Not much that has changed with this topic in awhile, so even if it might seem outdated it likely is not.
Response Signature
Response Signature
