SSO with CUCM 10.5.2 and Jabber 11.5.1
Peter Valdes
Level 3
Level 3
I'm trying to disable SSO on Jabber to bypass ADFS. After setting the SSO_Enabled parameter to FALSE in the jabber-config.xml, restarting TFTP services, the error "Error while processing SAML Response" comes up.
For CUCM page works perfect "Recovery URL to bypass Single Sign On (SSO)"
Any way to completely bypass on Jabber? Clients will have to manually type their AD username and password which is not a big deal.
Peter Valdes
Level 3
Level 3
Disabled SAML SSO on voice clusters which fixed the problem.
I don't see any benefits on having SAML SSO on Voice Server.
