Standby PRI not working with voice Gateway Router & CUCM
Sandipan Khatke
Hi ALL ,
GOOD Day all of you .
I am facing a big problem i.e  standby PRI not working with VG & CUCM , I have checked all the configuration parameter on VG & CUCM found ok but I am unable to make any call from standby link also incoming not come on the standby link . When I make a call on my Pilot no but getting busy tone .
I observer the some errors on VG like Cause i = 0x8286 - Channel unacceptable on my second PRI channel .
Please help me to reslove this proem .
Following are the PRI configuration Parameter on CUCM .
Product Specific Configuration Layout
Line Coding  : HDB3
Framing  : NON CRC4
Clock  : External
Input Gain (-6..14 db)  0
Output Attenuation (-6..14 db)  0
Echo Cancellation Enable
Echo Cancellation Coverage (ms)  64
PRI configuration on VG
interface Serial0/0/1:15
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
BR,
SANDIPAN
Craig Dyer
Level 3
Level 3
Sandipan,
     The error is coming from the telco switch,
     82—the public network near the local user (local telco switch)
     86- Channel unacceptable The service quality of the specified channel is insufficient to                 accept the connection. The call attempt fails because the channel is unusable.                               If you use a PBX, check the configuration of the PBX. For a PRI,                 find out how many channels your telco provides.
     Could you post more of the error debug?
     Which channel are you trying to pass the call out? Try reversing the channel selection order as a test.
     Is this a full 30 channel E1?
     The best advice I can give you is speak to the ISDN provider as this line may not be provisioned ready for use or may not be a full 30 channel E1.
Hope this helps,
Craig
Hi Craig ,
Thanks for your reply .
We are using the full 30 channel E1 PRI .
following are PRI Channel Statistics:
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 1. Layer 3 output may not apply
ISDN Se0/0/0:15, Channel [1-31]
  Configured Isdn Interface (dsl) 1
   Channel State (0=Idle 1=Proposed 2=Busy 3=Reserved 4=Restart 5=Maint_Pend)
    Channel :  1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1
    State   :  0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
   Service State (0=Inservice 1=Maint 2=Outofservice 8=MaintPend 9=OOSPend)
    State   :  0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Please find following debug error
VG_RO_01#isdn test call interface serial 0/0/0:15 09665484798
Mar 7 03:00:54.570: ISDN Se0/0/0:15 Q921: User RX <- RRp sapi=0 tei=0 nr=5
Mar 7 03:00:54.570: ISDN Se0/0/0:15 Q921: User TX -> RRp sapi=0 tei=0 nr=4
Mar 7 03:00:54.570: ISDN Se0/0/0:15 Q921: User TX -> RRf sapi=0 tei=0 nr=4
Mar 7 03:00:54.574: ISDN Se0/0/0:15 Q921: User RX <- RRf sapi=0 tei=0 nr=5
CCIL_PUNE_DR_VG_RO_01#
Mar 7 03:00:55.994: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Called num 09665484798
Mar 7 03:00:55.994: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=5 nr=4
Mar 7 03:00:55.994: ISDN Se0/0/0:15 Q931: SETUP pd = 8 callref = 0x0084
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Called Party Number i = 0x81, '09665484798'
Plan:ISDN, Type:Unknown
Mar 7 03:00:56.006: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=6
Mar 7 03:00:56.018: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=4 nr=6
Mar 7 03:00:56.018: ISDN Se0/0/0:15 Q931: RELEASE_COMP pd = 8 callref = 0x8084
Mar 7 03:00:56.022: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=5
Mar 7 03:00:59.995: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=6 nr=5
Mar 7 03:00:59.995: ISDN Se0/0/0:15 Q931: SETUP pd = 8 callref = 0x0084
Standard = CCITT
Mar 7 03:01:00.007: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=7
Mar 7 03:01:00.019: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=5 nr=7
Mar 7 03:01:00.019: ISDN Se0/0/0:15 Q931: RELEASE_COMP pd = 8 callref = 0x8084
Mar 7 03:01:00.019: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=6
Mar 7 03:01:03.995: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=7 nr=6
Mar 7 03:01:03.995: ISDN Se0/0/0:15 Q931: RELEASE_COMP pd = 8 callref = 0x0084
Cause i = 0x80E6 - Recovery on timer expiry
Mar 7 03:01:03.995: ISDN Se0/0/0:15 **ERROR**: CCPCC_CallOrigination: SETUP timed-out (2nd T303) to NETWORK. The SETUP failed.
BR ,
SANDIPAN
