Suggestions for Cisco CUBE Router Hardware Platform
Kyle Sullivan
I am building a new Cisco collaboration lab environment for CUCM 12.5 / and supporting collaboration applications. I am looking for recommendations for a modern Cisco router platform and IOS to configure CUBE, DSP's, Call Manager Express and connect to an ITSP. This is a lab environment for learning, testing and developing compatible applications. I am getting confused if I should go in the direction for ISR 4000 or 1000 series router and which OS/ licensing is required.
Kyle
Vaijanath Sonvane
All router models belonging to Cisco 1100 ISR supports CUBE functionality in Cisco IOS XE Gibraltar 16.12.1a onwards. You can find router part numbers in this URL:
https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/datasheet-c78-739512.html
You need to order CUBE licenses separately using L-CUBE Part number.
For 4321, you can use ISR4321-VSEC/K9.
Please note that many features such as DSP, Transcoding, High Availability etc. are not supported by ISR 1000 Series. You can check below URL for more details:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/supported-platforms.html
I would recommend to go with Cisco 4000 series (except 4221) as it supports all voice related features.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
5 Replies 5
Supported platforms for cube 14, you can go with 1000 platform.
Table 2.        CUBE Platform Support
Router platform
Minimum memory requirement
Maximum trunk sessions
Maximum sustainable call setup rate (Calls per second)
Cisco 1100 ISR1
Default
500
Cisco 4321 ISR
4 GB
500
Cisco 4331 ISR
4 GB
1000
Cisco 4351 ISR
4 GB
2000
13
Cisco 4431 ISR
8 GB
3000
15
Cisco 4451-X ISR
8 GB
6000
40
Cisco 4461 ISR
8 GB
10,000
55
C8200-1N-4T
8GB
2500
14
C8300-1N1S-6T
8GB
7000
40
C8300-1N1S-4G2X
8GB
8000
45
C8300-2N2S-6T
8GB
7500
42
C8300-2N2S-4T2X
16GB
10,000
55
Cisco CSR 1000V / C8000V 1vCPU2
4 GB
1000
Cisco CSR 1000V / C8000V 2vCPU2
4 GB
3000
20
Cisco CSR 1000V / C8000V 4vCPU2
8 GB
6000
30
Cisco ASR 1001-X
16 GB
12,000
50
Cisco ASR 1002-X
16 GB
14,000
55
Cisco ASR 1006-X with
RP3 and ESP100/ESP100X
16 GB
16,000
65
Cisco ASR 1004 / ASR 1006 /
ASR 1006-X with RP2 and ESP40
16 GB
16,000
Response Signature
Thank you Nithin. Can you point me in the direction on where to find the part numbers for for VSEC/ K9 and licensing for ISR 1000 / 4331 routers? I've been looking on Cisco Website, but haven't had much definitive luck.
Thanks again,
Kyle
As @Vaijanath Sonvane  mentioned go for ISR 4k.If you are planning for BOX-to-BOX redundancy you need to go with 4331. Isr 4321 has only  two network port so  box to box redundancy won't be possible.
CUBE smart license ordering information
Product code
Description
L-CUBE
Top-level part number. Select this first
CUBE License options
CUBE14-T-STD
One Standard Trunk Session License
CUBE14-T-ENH
One Enhanced Trunk Session License (Includes support for box-to-box redundancy)
CUBE14-L-STD
One Standard Lineside License
CUBE14-MP
Entitlement for one Media Fork with support for box-to-box redundancy
Response Signature
Vaijanath Sonvane
Vaijanath,
Thank you and everyone that replied to my post for the help and guidance.
Kyle Sullivan
