TFTP Question
scooter817
Level 2
Level 2
Hello Eveyone
I'm currently reading the SRND for CUCM 9.X and it stated that the 8900 and 9900 series phones get there TFTP file over HTTP because it's much faster. Can anyone tell me where in CUCM is this configured at so that in case you want to change the phones to pull form the TFTP server instead of HTTP.
Eric
William Bell
Eric,
I don't think it is possible to modify this behavior. The phones will connect to TCP port 6970 on your TFTP node. I have never seen a way to modify that. Then again, I never looked because I prefer the "new" behavior myself.
-Bill
(b) http://ucguerrilla.com
(t) @ucguerrilla
Please remember to rate helpful responses and identify helpful or correct answers.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
William Bell
Eric,
-Bill
(t) @ucguerrilla
Thanks William I just wanted to know if it could be modified because I do prefer this myself.
