Translation to string with pause
Scott Bailey
I'm looking for a way to have a translation where our users can dial something, and have it routed to a number with an account code.  On phones I can do a speed dial, however I'd like for users/nurses in rooms off of analog gateways (patient rooms) to be able to dial something for language services.  I've looked into seeing if I can do this in UCCX, Unity Connection, or have some sort of dial-peer setup on a gateway.  In looking at forums it appears there may be able to do this with a TCL script on the ISR's.  Any guidance would be appreciated.
Example, users dial 1234, have it be translated to 888-123-4567,,1234,,5678 (with an account code and PIN)
b.winter
Google / Forum search is your friend:
https://community.cisco.com/t5/collaboration-knowledge-base/pause-in-speed-dial-cucm-9-x/ta-p/3150844
Probably also working with translation or route pattern. But as always, you are free to test it on your own.
AFAIK this does not apply to translation or route patterns. Pause is applicable to speed dials.
Response Signature
