trunk between two different CUCM (10.5 and 11.5)
vinney koul
Hi Everyone,
can anyone help to find a solution to create a trunk between two different version of cucm
Site A : CUCM 10.5
Site B : CUCM 11.5
can we do inter cluster between two site...
please help if anyone one have documents please forward me on Vinney.h.koul@gsk.com
Vinney Koul
R0g22
Yes you can. Use either H.323 ICT or SIP trunk. Recommended is SIP since H.323 is basically a dying protocol. You can google up or search CSC and should find numerous posts.
Thanks a lot for you help so I have to create a trunk between two different versions of CUCM....
Ratheesh Kumar
Hi there
Thats right. Go with SIP. The below document could be your best bud
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/19200-intercluster.html
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
Hello Vinney,
As Nipun mentioned, we highly recommend to use the SIP protocol to configure trunks, since H.323 is not longer receiving any new features or development.
Referring to the CUCM SRND:
"While H.323 trunks are still supported, SIP trunks are the recommended trunk type for Unified Communication deployments because SIP trunks provide additional features and functionality not available with H.323 trunks."
I recommend you to check the following SRND and the System Configuration guide for more details (taken out of CUCM version 11):
Cisco Collaboration System 11.x Solution Reference Network Designs (SRND)
Chapter: Cisco Unified CM Trunks
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab11/collab11/trunks.html
System Configuration Guide for Cisco Unified Communications Manager, Release 11.5(1)
Chapter: Configure SIP Trunks
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/11_5_1/sysConfig/CUCM_BK_SE5DAF88_00_cucm-system-configuration-guide-1151/CUCM_BK_SE5DAF88_00_cucm-system-configuration-guide-1151_chapter_01110.html
Process is the same for 10.5.
Regards!
Ivan
