03-13-2014 01:38 AM - edited 03-19-2019 08:00 AM
Hi All,
I'm going to change passwords for all the UC components which running on production environment. Below are the components
1. CUCM
2. CUPS
3. CUC
4.CCX
5. ESXi
6. CIMC
Please advise if there's any dependancy effected during the password changes?
Solved! Go to Solution.
03-13-2014 04:50 AM
CUPS, CCX, and CUC could all conceivably have a dependancy if the default administrator account was used instead of creating a dedicated application user on CUCM. You would need to check their config to be sure.
CUPS: CUCM Publisher
CCX: Unified CM Configuration
CUC: AXL Configuration
03-13-2014 04:50 AM
03-16-2014 07:53 PM
Hi Jonathan,
Thanks for your clarification. I'll check on the components mentioned above.
