UC on UCS co-resident Secure ACS 5.x VM
boonchin.ng
Is co-resident of Secure ACS 5.x VM with UC VMs supported? If yes, what consideration to take note of in addition to the TAC technote (http://www.cisco.com/en/US/products/ps6884/products_tech_note09186a0080bbd913.shtml)
Appreciate your kind advice.
Cheers!
skilambi
If the UC product has Full next to it then it means it supports full co residency. There is nothing more from the UC side, ensure there is no oversubscription of the CPU, Memory, HDD pay attention to TAC guidelines and finally you cannot use VMware FND license. have to use STD or higher.
Srini
Hi Srini,
As usual, thanks for the fast response.
