06-18-2015 10:54 AM - edited 03-19-2019 09:42 AM
Hey all...
Does anyone know if Finesse, running on Citrix XenDesktop (or any other VDI) supports monitoring and recording services in version 10.5? I've looked around but the documentation is vague.
Thanks!
-Sam
10-28-2015 10:43 AM
Might not be helpful, but I have used Finesse 10 and Calabrio on VDI's and we were able to record the call and users screen.
10-30-2015 06:28 AM
I've deployed it on couple of occations and it works fine as the call never goes through VDI unless you use softphone which is different discussion. Make sure your VDI environment meets the version requirements:
http://docwiki.cisco.com/wiki/Unified_CCX_Software_Compatibility_Matrix_for_10.5(1)
10-29-2015 06:03 AM
First of all, for Finesse recording and monitoring UCCX does not play any role. Finesse Monitoring is done through the CUCM and is being invoked through the BIB of phone. Hence, as far as you are using a supported IP Phone you are good there. For recording on Finesse, you need MediaSense and that too works on the concept of forking either phone based (using the BIB) or cube based (dial-peer based forking) so you are good there as well. No need to worry about the desktops you are running there i.e., physical or virtual.
Deepak
