UCME and Unity Connection Integration MWI Issue.
I have two Clusters UCME and CM cluster that need ilntegration between it,I have MWI issue after I setup the integration MWI for the CME cluster does not work Althought I have the Voice Message in the inbox but the MWI on never work for the Phone register with the CME (SCCP) however the MWI for the CM clsuter Phones work very fine.
Unity Connection 8.0.3
UCM : 7.1.3
UCME: 7.1
Rob Huffman
Hi Karim,
Just wondering if this was the doc you followed for the integration?
Cisco Unified Communications Manager Express SCCP Integration Guide for Cisco Unity Connection Release 8.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/integration/guide/cucme_sccp/cucintcucmesccp.html
Cheers!
Rob
HI Rob,
Yes It is,But I will double check my configuration again maybe I missed something.
