Unable to register MGCP Gw with CUCM
Yasir@1995
Dear Team,
We are unable to register the MGCP Gw with CUCM, Show ccm manager output showing as "registering".
We have done multiple troubleshooting,  but no luck. I am attaching the output for debug mgcp packets, debug mgcp events.
Please help us to understand what is there in the logs.
b.winter
Can you share the config of the GW and a screenshot of the CUCM config of the gateway (Device --> Gateway).
Probably the name of the GW doesn't match the FQDN, which the GW is sending:
RSIP 607144485 S0/SU1/DS1-1/24@Axis_Bank_PRI_Gateway1.axisb.com MGCP 0.1
The FQDN in CUCM has to match exactly the FQDN configured on the GW. 
7 Replies 7
Yasir@1995
b.winter
Thanks for your suggestion.
Will do the necessary changes and will update the status here.
Any update on this? Could the issue be resolved?
yes. as per your suggestion we have modified the GW name, and it registered.
Thanks for your help
Why did you mark your own response as a solution to your question? What @b.winter suggested is per your later response the solution to your question.
Response Signature
it was a mistake, rectified it.
