Unity 4.1(2) - changing LAN IP address
Afternoon all,
I wish to relocate an old Unity server of ours to a new location which involves changing the IP address, subnet and default gateway of the physical server.
The CUCM cluster integration with Unity will remain the same. Also, the subscriber accounts will also remain the same.
Will I be ok to change the NIC card settings and reset the voicemail ports without too much disruption? Is there anything else I need to consider?
Thank you kindly.
Jamie
2 Accepted Solutions
Jaime Valencia
Have you reviewed the documentation on that??
Changing the IP Address of a Cisco Unity  Server
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/42/upgrade/guide/ex/ru_090.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Tommer Catlin
Also check to make sure this server is not Voicemail only setup.  If it is, you will have many windows problems.  The IP is linked to Exchange, DNS, AD, etc within the system.  If the Unity server is a member server, the document above will work fine.  You will need to reboot the system like any MS Windows server once you change the IP address.  Unity after reboot will connect CUCM and register the ports again (if you are using SCCP for VM ports)
Jaime Valencia
java
java
Thank you kindly. Most helpful.
Jamie
Tommer Catlin
