Unity 4.2 Upgrade to Unity 7/8 or Unity Connection 7/8?
stafford.slater
Hi There,
I am after some advice on a Unity Upgrade, I have to carry out an upgrade of a Unity 4.2 server on same hardware it is VM only and running on Win2000. I have CUWL licencing so I can upgrade to either Unity or Unity Connection, I know I need a complete rebuild of either Win 2003 or Unity CNX 7/8 are both migration routes the same, is there any benefit of one over the other? Would you move to Unity 8 over 7 is it mature enough now?
I plan on carrying out COBRAS export of old Unity 4 (No VM's)
carry out COBRAS export of old Unity 4 VM's
replace hard drive for fallback
Install new software
run COBRAS import
run cobras import of VM's
Any advice appreaciated.
Stafford
Rob Huffman
Hi Stafford,
Have a look at the excellent Blogs from Hailey @ CNC ...they ROCK! He also
has linked a really phenomenal presentation that you will find very helpful
https://supportforums.cisco.com/message/3179586
This link is really good as well;
Cisco Messaging Products: Feature Comparison
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps5745/ps2237/product_data_sheet0900aecd806bfc37_ps6509_Products_Data_Sheet.html
Cheers!
Rob
