Unity Connection 2 Questions
rod.blackie
Two questions chaps.
1st - Can Unity Connection v2x run with a Call Manager 4.1.3 environment?
2nd - Can any of you point me in the right direction of any decent unity connection installation guides?
As always your help is greatly appreciated.
Rod
lindborg
All the Cisco docs for CUC (including 2.1) can be found here:
http://www.cisco.com/en/US/products/ps6509/tsd_products_support_series_home.html
The oldest CM version supported according to the compatibility matrix found at the site above is 4.2
lindborg
Thanks Jeff.
Rob Huffman
Hi Rod,
Sadly 4.1(3) is not supported.
Supported Version Combinations for Cisco Unity Connection 2.x and Cisco Unified Communications Manager
Cisco Unified Communications Manager 6.1(x), 6.0(x), 5.1(x), 5.0(x), 4.3(x), 4.2(x)
From this good doc;
SCCP Compatibility Matrix: Cisco Unity Connection, Cisco Unified CM, and Cisco Unified CM Express
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html
Installation Guide for Cisco Unity Connection Release 2.x
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/2x/installation/guide/2xcucigx.html
Hope this helps!
Rob
Edit: Beaten to the punch by the Unity guru Jeff ;-)
Thanks Rob, I was expecting the first reponse from you.. but well done to jeff.
3 points for giving me a direct link to the uc install pdf.
Thanks to all
Rod
