Unity Connection 8.5 Monitoring
petrojosh
Level 5
Level 5
Is there an easier or better way to monitor Connection's status than
using RTMT and a Kiwi Syslog box? I do not like the fact that if I log off of the server running RTMT it closes RTMT until I login and start up again. Is there a way to run RTMT as a service? Any suggestions?
Tommer Catlin
Can you explain what you are trying to monitor on it?    You can configure SNMP alerts to be sent if you are worried about one the MIBs.   Or SMTP alerts.  Its based off the same code as CUCM and the alert configuration should be similar.
clileikis
Level 7
Level 7
Hi there,
If you're talking about Unity Connection port monitoring, have you checked out Connection Remote Port Status Monitor:
http://www.ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/Help/Connection%20Remote%20Port%20Status%20Monitor.html
As Tommer mentioned, you'll have to describe the type of monitoring you're looking for (SNMP, etc)
HTH,
Chris
Please rate helpful posts
