Unity Connection 8.6 compatibility with CUCM
Hasrat Raja
I am upgrading Unity Version 8.0.3 to 8.6, my current CUCM version is 8.0.2. According to following link:
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/unified/communications/system/versions/IPTMtrix.html#wp1016708
I will need to upgrade CUCM to 8.6 also, please confirm if this is the case, also can I upgrade to any CUCM 8.6 version available ?
thanks
hasrat
Rob Huffman
Hi Hasrat,
That doc just refers to the "tested" version but in fact any Unity Connection
version 2.1 or later will work with any CUCM version 4.1(3)or later
So you really don't need to upgrade CUCM at this time if you don't want.
Here's the clip;
Supported Version Combinations for Cisco Unity Connection and Cisco Unified Communications Manager
Cisco Unity Connection 2.x and Later
Any version of Cisco Unity Connection 2.x or later is supported for use with any version of Cisco Unified CM 4.1(3) or later.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html
Cheers!
Rob
"May your heart always be joyful
May your song always be sung" - Bob Dylan
Rob Huffman
Hi Hasrat,
Here's the clip;
Cheers!
Rob
Hi Rob,
thank you for calrifying, I saw the document but missed the note.
thks again
hasrat
