Unity Connection Alternate Greeting dates are wrong
dannoofWI
Unity Connection 10.5.2, when enabling the alternate greeting and setting an endate, all months until March 2016 are announced with 1 day less than should be available. For example - the month of November only goes to the 29th yet there are 30 days.
This only happens using telephone interface, using PCA November 30th is a choice.
5 Replies 5
Manish Gogna
I am not exactly sure but it could be related to the following bug filed recently
https://tools.cisco.com/bugsearch/bug/CSCur89579/?reffering_site=dumpcr
Plz check if you are running one of the folowing or higher versions of 10.5.2
10.5(2)ES10
10.5(2.11005.1)
10.5(2.11900.2)
Manish
- Do rate helpful posts -
Thank you Manish,
The bug you refer to is about the time being incorrect. I also have that problem.
I have opened a case with TAC so I will see what they say.
Dan
Hi Dan,
I hope both the issues are taken care of with one fix :)
Manish
Dan, Did TAC get back to you on a resolution?  We're running 10.5.1.10000-7 here and experiencing the same issue.  I tried November and December and both failed to go out the full month.  Thanks.
Their suggestion is to patch Unity to SU2a. I have not been able to do that yet but I will report back the results.
Dan
