Unity Connection Data Error 10006
bruce.wilkinson
Hello
I'm hoping someone can help me quickly here.
I'm running a CUC training class in Singapore and am getting an error "Data Error 10006".
This error occurs when I try to change the password settings on a new template and when I try to create a new call handler.
All other functionality seems to work just fine.
I have loaded SR1 and ES1 plus the CUC upgrade wizard.
The hardware I'm using is MCS 7825's with W2K3 standard edition SP1
I used the 'nopcd' command to load the application.
Any help would be gratefully appreciated
Bruce Wilkinson
mapennin
Hi Bruce - that's an error from SQL Server, not one of our own error codes:
"The provider indicated an invalid pointer was used."
I haven't seen that before in our testing - make sure you have the correct version of SQL Server/MSDE installed.
- Matt
hi matt
i am also facing this error, and i didnt install the SQL Server/MSDE seperatly. Cisco Unity Connection installation automaticlly installs the SQL.
by the way i tried to install SQL MSDE SP4 but the error still there
I think we eventually solved this. Turns out it was a timezone inconsistancy of all things. check that the time zones in the templates, subscriber profiles and the machine are all consistent.
Bruce Wilkinson
