unity connection forwarding rules
mark.carroll
hi folks
trying to create a forwarding rule in unity connection, basically i cfwdall my 13xx ext to cti rp 777. I want to avoid using a vm profile under 13xx ext so thats where the forwrding rule comes in, I want to get calls hitting 13xx to hit a handler. I cant seem to get the forwarding rule to work. Ive tried creating a new rule that says send call to specific handler and edited the rule saying forwarding station equals 13xx etc, basically Ive tried a good few options here but i cant seem to get the rule to work, calls are just being forwarded to unity as opposed to handler. any ideas?
thanks
Chris Deren
Are you building forwarding rule?
Use port monitor to see exactely what digits are arriving.
Chris
Chris Deren
Chris
port monitor did the trick thanks
