Unity Connection Greetings
bobby.jacob
Hi all,
How can we change the Unity Connection default greeting instead of saying name, change that to the extension number.?
tnx
Bobby
jeff.singh_2
Level 3
Level 3
hi, can't remember the exact place but I think its on the admin page , advanced settings - something like disable name search or enable number search. Remember doing something similar for someone and found the setting there.
Rob Huffman
Hi Bobby,
I'll just add this note to the good tips from Jeff (+5)
The first thing you need to do is replace the User>Display Name with
their extension, so in this example, user Bob Uncle is edited to show
Display Name 5126. Then we need to remove Bob's recorded name.
An excellent way with Unity Connection is with the use of this great tool from
the fine suite of Unity Tools (** reset feature**);
Unity Connection Bulk User Delete
For resetting users you have the option of emptying the mailbox ,  resetting greetings, deleting voice names,  resetting passwords,  removing private lists and a number of other  options you may choose.   For installations where the user base “changes  over” frequently such as  schools this may be a nicer option.  This  option is also allowed for  CoRes installations since it does not  involve the removal of user  objects from the Connection database.
http://www.ciscounitytools.com/Applications/CxN/BulkUserDelete/BulkUserDelete.html
Then ensure that the greeting page for Bob is set to use the System Default Greeting. I just tried this in
the lab and was able to change;
"Sorry, Bob Uncle is not available"
to
"Sorry, 5126 is not available"
Remember to uncheck the checkbox for;
on the Conversation page so that you won't have to reset newly created users
Cheers!
Rob
"Hours are like diamonds, don't let them waste
Time waits for no one, no favors has he"
- Stones
