07-27-2011 01:54 PM - edited 03-19-2019 03:21 AM
Greetings,
I'm having difficulty finding the answer to this on the cisco website. I am planning to upgrade my unity connection cluster from v 7.1.3 to 7.1(5b). My hardware is mcs-7845h2-k9-uca1. Is this ok to go to 7.1(5b)?
Beth
07-28-2011 07:09 AM
Hi Beth,
Just to add another reference to the great tips from Justin (+5)
Your server is, in fact, supported into the 8.x (8.5) train so you are good to go;
Feature | Description |
Model numbers | Cisco, version 1: • • Cisco, version 2: • • Cisco, version 3: • • HP DL380G5 Dual Processor |
Supplier | Shipped by Cisco or provided by customer; manufactured by HP |
Platform overlay | 3 |
Form factor | Rack-mount |
Mounting | 2 RU |
Processor(s) | Intel Dual-Core Xeon Woodcrest 2.33-GHz processor |
RAM (as shipped) | 4 GB |
Hard disk | Version 1: Eight 72-GB hard disks Version 2: Four 72-GB hard disks Version 3: Four 146-GB hard disks |
RAID controller | P400 controller (part number: 405132-B21) |
RAID configuration | RAID 1 |
Total available disk space | Version 1: 134 GB after you remove four hard disks to support Connection 8.x, or 272 GB if you replace 72-GB hard disks with 146-GB hard disks to support Connection clusters Version 2: 134 GB, or 272 GB if you replace 72-GB hard disks with 146-GB hard disks to support Connection clusters Version 3: 272 GB |
Hardware reconfiguration required | Version 1 servers require that you: • • Version 2 servers require that you replace 72 GB hard disks with 146 GB or larger hard disks. |
Battery-backed write cache enabler (BBWC) | BBWC enabler (part number: 383280-B21) |
CD-ROM or DVD-ROM drives | 1 DVD-ROM drive |
Tape drive | Optional |
Power supply | Redundant |
Remote management | Yes |
Total number of available ports (Voice + TTS + Voice recognition) per server | 144 |
Total number of users with mailboxes | 10,000 |
Number of Cisco Personal Communications Assistant users | 10,000 |
Total number of LDAP corporate directory users | 10,000 |
Approximate message storage, G-711 codec, minutes | Versions 1 and 2: 97,500 Version 3: 240,000 |
Field-replaceable spares part numbers | Memory: MEM-7845-H2-1GB= Hard disk: HDD-7845-H2-72= and HDD-7845-H2-146= Power: PWR-7845-H2= Fan: FAN-7845-H2= |
More information | http://www.cisco.com/en/US/partner/products/hw/voiceapp/ps378/products_data_sheets_list.html |
Cheers!
Rob
10-22-2014 02:04 PM
Hi Beth,
It's usually a safe bet that if your upgrading within a major release that you do not have to upgrade your hardware but you can always check in the release notes for the upgrade.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/release/notes/715cucrn.html#wp506366
HTH,
Justin
