Unity Connection Password Question
scooter817
Level 2
Level 2
Hi Everyone
I wanted to know is there a query or program that I can run that will show me when the last time a user changed their VM PIN.
Eric
Rob Huffman
Hi Eric,
You can use CUDD from the great Unity tools for this query;
  • Time of last password change.  Indicate the date and time the user changed their phone password (PIN).  This value is converted into the local time of the computer you are running User Data Dump on.
From;
http://ciscounitytools.com/Applications/CxN/UserDataDump/Help/UserDataDump.htm#_Toc359835396
Cheers!
Rob
Rob Huffman
Hi Eric,
From;
Cheers!
Rob
