Unity Connection System Call Handler Take Message
Bernardo34
We use Unity Connection 2.1.4 integrated within CUCMBE.
Our Customer wants to disable the system call handler that comes after a personal greeting.
For Example: When you get to a Voicemail with personal greeting you will here: something like this: This is my Voicemail. you can leave me a message after the beep. Then you hear the Unity System Call Handler that you can leave a message as well. Is it possible to disable this?
thanks in advance,
Bernhard
Hi Bernard,
I think it isn't possible to modify it in uc2
but it is doable in 7
thanks
Hi, can anybody confirm that the call handler after the personal greeting can only be disabled in UnityConnection v7?? I have the same issue as Bernhard using Unity Connection 2.1.0.9901-362.
I would appreciate any feedback!
Hi There,
You won't find better confirmation than from Mr.Lindborg himself
https://supportforums.cisco.com/message/1197866#1197866
Cheers!
Rob
thanks so much! 🙂
